Help! Why have my 1...
[Closed] Help! Why have my 120-150mm u-turn Revs become 105-135mm!?
They sit on the hardtail, travel is rarely changed. But I notice yesterday they were sitting lower than usual- and their travel range has changed it seems!
Everything else appears to be ok.
Posted : 13/01/2013 12:07 pm
Lost air pressure in the +ve chamber possibly. Having a higher -ve pulls them down into the travel.
Posted : 13/01/2013 12:22 pm
I had a similar thing with my dual air revs...
Too much -ve vs +ve pressure. Didn't work just to top up one side though, had to empty both and start again.
Posted : 13/01/2013 1:29 pm
U-turn is a 'solo-air' type so no way to balance the two yourself. Happened to my air u-turn Pikes. Changing the o-ring between the chambers helped and making sure it was never dry (squirt a couple of ml's of fork oil through the valve once every so often).
Posted : 13/01/2013 1:34 pm
They are definetly dual air warpcow. 2010 teams if it makes a difference.
I know about the negative/positive imbalance, so a seal is what I expect when they get opened!
Posted : 13/01/2013 1:42 pm
When was the last time they was service. Could be the seal head has gone and you have too much oil in the lower legs now.
Posted : 13/01/2013 1:50 pm
Seal head? Been a while!
Posted : 13/01/2013 1:59 pm
My Teams have a habit, over time, of pushing air from the positive chamber into the negative, which gives the effect you describe. Just need the pressures reset and they're fine. Is it that?
warpcow - Member
Nah, just completely wrong.
Posted : 13/01/2013 2:07 pm
๐Ÿ˜ณ Not sure how I got that one wrong. I even have them sitting in the other room and topped them up just the other day ๐Ÿ˜ณ
The rest of what I said still worked for me though.
Posted : 13/01/2013 3:54 pm
