Help needed with St...
[Closed] Help needed with Stumpy FSR mounts
5 Users
Hi ppl
I have just bought a 2011 Specialized S-Works Stumpjumper FSR carbon and want to put a top chain guide on it. I wont need a chain tensioner as I have the new Type 2 X0 rear mech with clutch so that will take care of chain tension. My problem is I do not know which mount to buy. Am I correct in that direct mount and e type are different fittings? I have looked on Specialized and they only did the frame only in S-Works guise for 2011 and therefore does not state which mount it is. If I look at 2012 it says S3 direct mount and the 2011 expert says S1 direct mount and my lbs said it was e type. Now I am super confused...
Do I need direct mount or e type, what's the difference between S1, S2 and S3?
Any advice would be appreciated.
Craig
Posted : 03/02/2013 10:44 am
A spesh direct mount front mech is just an etype mech with the bb mounting plate removed and then bolted directly on the frame using the holes which the plate ataches to, Which is different to a normal direct mount front mech that bolts to the seat tube,
So they're both right really.. I'd wait for the frame then eye it up, if its a bb30 bottom bracket type thing then an etype one won't fit and if its a bolt on type then a seat tube one might not fit either
It can be a minefield...
Posted : 03/02/2013 10:49 am
I think so, are the front mech mounting bolt holes side by side on your frame like the guide ones you linked to? If they are then yes.
Posted : 03/02/2013 11:03 am
I'll have to take a proper look when I go to the bike.
Any idea what S1, S2 and S3 are then?
Cheers for your help.
Posted : 03/02/2013 11:06 am
No idea what the s1-2-3 thing is, it gets confusing with spesh tbh, that's why I'd wait til I had the frame in my hands to make sure..
Have fun.. 😀
Posted : 03/02/2013 11:08 am
I wish all the manufacturers would club together and start making stuff that was compatible across the board.
Posted : 03/02/2013 11:24 am
I can't remember which one i went for, but got the specs off the spesh website, don't forget as well as 2x10 and 3x10 they come in different sizes to suit what ring sizes you run as well. So choose carefully
Posted : 03/02/2013 11:27 am
2011 stumpy will use either a s1 SRAM front mech or a shimano e type with the plate removed
Frame should come with a bracket that goes between the frame and the e type mech
But as above I'd wait till frame arrives and see what you get
Posted : 03/02/2013 11:36 am
Picked Kevins S Works up yesterday after it was built up. Its fitted with an XT E type front mech. It a 2011 carbon one.
Posted : 03/02/2013 12:10 pm
@Tracey That's the same year as my bike. I called Specialized today and he simply said 'S1'
I asked him to elaborate a little and then he said 'S1 chain guide'...mmm, not the most helpful fellow!
Posted : 04/02/2013 6:33 pm
