Help, mixing 9 and ...
[Closed] Help, mixing 9 and 10 speed components
Hi all, currently running 9 speed Xtr shifters,front and rear mechs & cassette. Would like to swap to Xtr shadow plus rear mech. If i swap to a 10 speed shifter with the shadow plus is this compatible with my 9 speed crank / cassette / chain /? ๐Ÿ˜ฏ Thanks in advance
Posted : 22/10/2012 4:00 pm
In short - no.
Posted : 22/10/2012 4:14 pm
My understanding is you would need
10spd rear shifter
10spd cass
10 spd chain
Can keep
Front 9 spd shifter
Front mech
Current c/set ( but could ultimately change rings to 10 spd if they suit your crank)
I think above is correct but may be wrong
Posted : 22/10/2012 4:34 pm
That's about the gist of it. You will need chain and cassette as well.
Posted : 22/10/2012 5:02 pm
Usually sorted with a bit of filing
Posted : 22/10/2012 5:07 pm
Cheers guys, thanks for the help. Will have to look at another method to stop noisy chain slap on my 5 Spot
Posted : 22/10/2012 5:43 pm
