Need advice / help guys - after a rattling good run on my local trail on hogmanay the screw that fixes my shock to the clevis on my 2017 commencal meta am has disappeared - does anyone know if this can be sourced in the uk?
https://www.commencal-store.co.uk/Mobile/bolt-for-the-shock-and-clevis-for-meta-2015-c2x16973558
Give them a ring but that looks like a fairly standard bolt! And next time, check your torques often and use locktite! Your new bolt will lose torque on the first few rides so this will be especially important.
It looks like a standard thread and stuff but you might not be able to get something in that length with the same length shoulder, you might have to buy something longer and trim the threaded end to size.
What thread (diameter and pitch) and how long should the bolt be (total length from under the head to end of the thread)? We've got some stuff that might do the job if you don't get any joy from Commie.
