Helmet light with g...
[Closed] Helmet light with gopro mount.
Looks spot on that, might give it a whirl. Unless anyone on here wants to sell one they've produced?
Posted : 26/01/2016 11:12 am
My only issue is that my bar mount is aluminium as well and the tolerances mean that when tightened there's still a little play as the tabs are all bent in towards each other so it kind of pivots where tips of the 3 tabs grip the base of the 2 tabs and the bolt is undersized for the holes allowing a bit of play.
Whereas the plastic ones compress evenly so it's held in by friction rather than being pinched. Doesn't seem to be an issue as long as either the mount or the camera/light is plastic, only on my bar light where the light and the bar clamp are aluminium.
Posted : 26/01/2016 11:25 am
I'd love to give it a go if you don't mind popping one in the post? The solid one should work fine.
Just spotted this - have sent you over an email.
Cheers,
James
Posted : 29/01/2016 1:08 am
Page 3 / 3
