Hi All, just about to get a BFe (2nd hand off classifieds).
What size headset do I need?
Will a standard one fit?
What is a standard size?
I'm clue-less with headsets and all help is much appreciated.
"Seatpost diameter: 31.6mm (wise to get a decent length one)
Front Mech: 34.9mm (Top Pull)
Bottom Bracket width: 73mm
Headset: 1.125" only"
http://www.cotic.co.uk/product/BFe
Standard 1 1/8th. Have a look at the component sizes near the bottom of the page.
> http://www.cotic.co.uk/product/BFe <
Aaah OK
I thought that just meant to suit 1 1/8th fork steerer. I guess it also relates to the headtube size?
Yes otherwise it would not say 1 1/8th only? as an OS head tube would take and 1.5" and a 1 1/8" ๐
OK - got that bit.
So what's the difference between integrated and non-integrated then?
...can you tell by looking at the Cotic picture above which it is?
Its a std headset - There are 3 kinds.
Std - external cup like the hope one above
Semi-integrated (Zero-stack) - pushed in cups but recessed into head tube
Integrated - bearing just sit into head tube with just a top cap and crown race.
Hope have a good guide:
