Has anyone ever man...
[Closed] Has anyone ever managed to refit a Sram b-bolt plate?
7 Users
So, I just went to take my GX eagle derailleur off my hardtail and when the bolt holding it onto the dropout came loose a couple of parts pinged off into the floor. After searching around to find these, and having a quick look online, it seems that the part that came off is the b-tension bolt plate (and horrible spiral Circlip thing) that also holds the main hanger bolt in.
A quick google search has brought up the video below showing this part being put back in but it looks like the sort of thing that may drive me mad if I start to attempt it.
Has anyone successfully managed to reassemble these parts before? Should I just get myself a glass/bottle of wine and sit down to try and get it done? Would I be better off just stabbing myself in the face for half an hour before going and ordering a new (shimano) mech and shifter (or trying to make a warranty claim for a failed part)?
Posted : 29/08/2019 10:02 pm
Yes, I've swapped out the mech pivot bolt after it's got sloppy.
Best advice I can offer is use a ball.point pen to run round the flat coil spring as you hold everything in place. Might take a couple of goes but it will work
Dont forget to get the ball point between the layers of the spring
Posted : 29/08/2019 10:07 pm
Looks to be more fiddly than difficult as such.
That said, it's the sort of job that I irrationally quite enjoy so I might rationally be excluded from giving you advice on this.😁
However,I would always advice having the beer/ wine after the repair as a reward. That always works better for me than getting bladdered during the (poorly attempted) repair.lol
Posted : 30/08/2019 12:57 am
carlos
Member
Yes, I’ve swapped out the mech pivot bolt after it’s got sloppy.
So it's the bolt wearing rather than the body of the mech causing the poor tolerances Carlos? Interesting to know that.
Posted : 30/08/2019 12:58 am
Hi OP, i have fixed one using the video you link to. it was to fix a spare mech to take with me on trans provence. i ended up loaning the mech to someone diring the race and they bust the bolt again.
Anyhow long story short, the circlip and spring are not needed. i spoke to both the mavic and sram mechanics and they said that they do not affect the function of the mech, they are basically there to keep the bolt in place if you take the mech off.
So in short, dont bother!
Posted : 30/08/2019 5:44 am
^^ That's interesting to know!👍
Posted : 30/08/2019 5:47 am
Yes. It's only when doing these sort of things that you realise that with the cost of labour it really is more economical to DIY or buy a new one.
Posted : 30/08/2019 6:30 am
Yes. SRAM mechs doing things like this is one of the reasons I minimise my use of them though!
Just watch your fingers as you need to wind it up quite a bit to get everything in place, the spring can jump out at inopportune moments. Pliers help.
I've done it a couple of times on Shimano road mechs too, as on the winter commute the salt can get in and stop the pivot moving so it needs occasional greasing - similar principle but the mech doesn't self destruct.
Posted : 30/08/2019 9:48 am
I do them semi regularly on customers bikes, a bit fiddly the first time until you get the technique.
Allen key or t25 clamped upright in a vice holds the mech/bolt nicely. If it has a wave washer then a clamp/molegrips can be used to compress the plate to mech leaving both hands free to install the clip.
Posted : 30/08/2019 10:54 am
carlos
Member
So it’s the bolt wearing rather than the body of the mech causing the poor tolerances Carlos? Interesting to know that.
Seems to be with the ones I've swapped about. TBF the actual pivots were also a bit slack but nothing you can do about that again
Reading the other posts I'll not bother next time though
Posted : 30/08/2019 10:34 pm
^^ Cheers for the reply mate.👍
Posted : 31/08/2019 3:23 am
I finally got some time out from the new baby to have a go at fixing this tonight and managed to get the circlip back on on the third attempt. So, nowhere near as annoying as I thought it was going to be.
I was very glad to be able to pull a dental pick, of a similar shape to the one used in the video, out of the tool box to use as that did make the whole thing much easier.
The derailleur is back on the bike now and if it does this again in the future I may be tempted to take the advice above and just leave it off as this isn’t a job I want to get too familiar with.
Posted : 06/09/2019 10:21 pm
Nice one mate, glad you got it sorted.
Posted : 07/09/2019 2:22 am
