Grommets and intern...
[Closed] Grommets and internal cabling, new Orange frame
Hello, I have a replacement Stage 5 Orange frame, I'm really struggling with the internal routing of the gear cable and brake hose. The main issue is inserting the rubber grommets, I would really appreciate any tips, help or wisdom with this. Especially if anyone knows the correct method of completing this task. Thank you.
Posted : 19/12/2021 9:13 pm
Found it impossible. I think you have to put the grommets in first and then thread the cables through.
Posted : 19/12/2021 9:42 pm
No you can fit the cable first .slide the grommets over the cable and apply some Vaseline and they go in without any issue at all
Posted : 19/12/2021 11:19 pm
apply some Vaseline
I’ve always used silicone lube, the stuff you get for push fit waste pipe from Screwfix and others.
Posted : 19/12/2021 11:28 pm
Leaving them in boiling water for a couple of minutes softens them up enough to go in relatively easily.
Posted : 20/12/2021 7:01 am
10 years after I last built an Orange I'm amazed that this is still an issue.
Posted : 20/12/2021 8:19 am
Mine arrives this week and whilst its a bit 'tricky', I remember doing my last one and its still no different to any other alloy frame without tube-in-tube.
Run a sacrificial gear inner through first, use that the route your outers. The grommets just push in bit by bit, warmed up makes it a bit easier.
Posted : 20/12/2021 9:31 am
Use lots of grease, and they should pop straight in.
Posted : 20/12/2021 9:56 am
Never have I read such a pack of lies.
OK, to be fair, most went in with a bit of a struggle (with a bit of light grease) but maybe some grommets were oversized or some holes undersized, as I have one stubborn little **** on each of my Oranges which just won't go.
Posted : 20/12/2021 10:07 am
 Olly
mine didnt have anything at the hole where the brake line comes out of the swingarm to the caliper.
Took a 20mm electricians grommet and trimmed it down. Perfect job.
Posted : 20/12/2021 10:25 am
Most grommets on my Four went in with a bit of grease, but the brake hose chainstay exit grommet was impossible.
Have they improved the internal dropper routing yet, or is that still a disaster requiring bb removal, small fingers and endless swearing?
Posted : 20/12/2021 5:03 pm
What happened to the original frame?
Did you have one that cracked or are you doing a new build / replacing frame from another bike?
Posted : 20/12/2021 5:08 pm
I sent the original frame back to Orange due to paint blistering. Upon receipt Orange found cracks in the frame. Orange replaced the frame, excellent service, considering the Stage 5 is no longer in production. Thank you for your replies, everyone.
Posted : 25/12/2021 12:38 am
 Daz
KY jelly
The wine told me to say it
Posted : 25/12/2021 12:59 am
