going to change to ...
[Closed] going to change to tubeless, and need some advice
[#5802927]
hi all,
bought a new winter bike with tubeless tyres 3 months ago. have not got a flat in that time and am now a convert. I wanted to change my full sus too but have ran into a few snags.
1.it has mavic 321 rims which are 28mm wide and all of the conversion kits that i have looked at are either 25mm or standard width (what ever that is, does anyone know of any wider ones?
2. can i run high rollers tubeless?
any advice welcome,
john
Posted : 27/12/2013 11:19 pm
http://superstar.tibolts.co.uk/product_info.php?cPath=73&products_id=693
and a set of their valves, plus some sealant, job done.
and yes to HR's even come in tubeless and LUST versions.
Posted : 27/12/2013 11:33 pm
thanks,
do you need to get tubeless specific high rollers?
Posted : 27/12/2013 11:42 pm
No you just need a ****in good pump!
Posted : 27/12/2013 11:49 pm
Just wrap a few layers of electrical tape around the rim to cover the spoke holes. Stick your HRs on with some sealant and blow 'em up (easiest with a compressor) and you'll be good to go
Posted : 27/12/2013 11:50 pm
EDIT oh you'll need tubeless valves of course,
Posted : 27/12/2013 11:51 pm
I use Gorilla tape in 1 inch width . only £4 on ebay . 1 layer is enough . cut valve from old tube , washing up liquid on tyre sides and sealant .
Posted : 27/12/2013 11:55 pm
/hijack/ sorry. I thinkin of tryin tubeless but my wheels are for schrader valves not presta can it be done
Posted : 28/12/2013 12:16 am
Stans kit for the 321 is the rhyno lite one
http://www.sjscycles.co.uk/stans-no-tubes-rhyno-lite-tubeless-kit-prod18828/
Issue i have seen and the reason i didnt get the kit is the 321's are at the cheaper end of the mavic rims and as they are only pinned (not welded) the joint can pull apart a bit at the top of the rim. This is apperently fine to ride on but means they will not seal tubeless
Posted : 28/12/2013 12:21 am
I haven't done a 321 but I got absolutely nowhere with a 719 and just tape- I could inflate it, though that wasn't easy, but I couldn't run it at a reasonable pressure and go round many corners before the tyre rolled straight off. The rim profile doesn't look very different. YMMV of course...
Oh, on a less opinionated front, tubeles kits don't usually care about external rim size, only the internal. Which for 321s I would have assumed is 21mm (Mavic website doesn't say).
Posted : 28/12/2013 12:23 am
ritchic. Freeride kits has schrader valves
http://www.chainreactioncycles.com/stans-no-tubes-freeride-tubeless-kit/rp-prod38837?_$ja=tsid:46412
Posted : 28/12/2013 12:24 am
I think you need the Rhyno kit
http://www.notubes.com/help_center_rim_strips.aspx
Posted : 28/12/2013 12:25 am
O so it seems I can do it then. What advantages are there apposed to slime tubes as it seems weight won't really be that different with all rime tape and slime in there
Posted : 28/12/2013 2:24 pm
This tubeless thing has troubled me for some time now.
I have heard that you cannot run very high tyre pressure when tubeless.
Being a Fatty I need high pressure to keep the tyre shape ( this may be why I end up getting so many punchers)
Posted : 28/12/2013 2:30 pm
