Gearing ratio'...
[Closed] Gearing ratio's / set-ups??? (Dual / Single / road blocks / 10spd blocks)
Got myself a Blur 4x and looking to change it from a traditional 27spd to something with better clearance.
My initial thought was a dual ring setup (22,36) with a 11;32 cassette.
However, I'm aware some people use road and 10spd cassettes combined with dual and single rings but know little about these set-ups.
Any advise on these set-ups would be greatly appreciated.
I will be using the bike for a bit of everything, from epic days out to sessioning play spots.
Many Thanks
Posted : 06/04/2010 1:45 pm
Road cassettes have narrower spreads, but closer gaps. Doesn't really achieve much unless you're racing DH and want the smaller gaps.
22/36 with an 11-34 cassette would give you a good spread and will cover most the ratios achieved with a 22/32/44 and an 11-32, save the top 1 or 2.
Posted : 06/04/2010 3:23 pm
22/36 11-34 for 'the win' apparently ๐Ÿ˜‰
Only sure way is for you to make am mental note of what gear combinations you use and those you feel you could manage without - it's your bike, legs and hills after all.
I really like a close spread cassette(used to use Ultegra but now slx) over the extra 'codger cogs', it allows me to keep a more constant cadence with far smoother changes
I've never found any problems with 22/36 11-28, but am really not a 'sit back and spin' rider preferring power over finnesse I s'pose
Posted : 06/04/2010 3:42 pm
Whilst I'd sooner have bigger rings and a wider cassette, avoiding the need to shift on the front so much, which in a race situation wastes time. I find the terrain changes far too much/quickly to be concerned about having a close ratio cassette. I did try a road block for a while, but just got irritated with having to drop onto the granny.
It's all personal.
Posted : 06/04/2010 3:54 pm
It's all personal.
I fully agree, that's why it's best to work out your own preferred ratios and gear your bike to suit you, not some twunt on the internet ๐Ÿ˜‰
Posted : 06/04/2010 4:07 pm
Less chainstay clearance than a std set-up though.
EDIT I guess he is talking about gound clearance though.
Posted : 06/04/2010 4:09 pm
Cheers for you help.
Guess I am still thinking of a 36/22 with a 32-11 cassette then.
Posted : 06/04/2010 4:42 pm
ive just set mine up with a 22/36 and 11-32 cassette. not tried it yet as im still injured but i was bored lol
Posted : 06/04/2010 5:13 pm
I run 24/36 with a 12-25 cassette, I did go to a 27 for the Alps
Posted : 06/04/2010 6:58 pm
