Garmin Edge Explore...
[Closed] Garmin Edge Explore and grid refs
2 Users
Is it possible to get this gps to show me Uk grid refs? I bet it can but don't know which combination of buttuns to press.
Anyone able to help?
Posted : 28/11/2021 8:43 am
Lets modify this a touch. I can find it but it is buried so far into the system that it takes about a dozen clicks to get there. I would like to either have it displayed or be just a single step into the menu really.
Posted : 28/11/2021 9:25 am
Download the Connect IQ app if you haven't already - search in there for grid reference and there should be a widget you can install then add that to your data screen.
Posted : 28/11/2021 9:29 am
People have said that before but down load it to what?
And then what?
Posted : 28/11/2021 11:11 am
Follow this
https://support.garmin.com/en-GB/?faq=4ISyzhi0vn2OrkPNGaonB8
Then at step 6 search for "grid reference" you should get a list that includes OS Grid Reference DF - select that one and install it onto your garmin
Once installed you can do a long press on any data field, tap the angle that appears top right to choose a different value to display then right at the bottom of the list you should find Connect IQ fields, that's where your grid ref will be. Tap that and you'll have grid ref displayed on a normal data screen. (I think - I'm doing the last bit from memory,)
Posted : 28/11/2021 12:43 pm
