Garmin 705 on MTB s...
[Closed] Garmin 705 on MTB stem?
8 Users
Ive had this Garmin 705 itch for longer than my job security has been dubious 🙂
Things at work totally suck and Im looking for an impulse buy to cheer myself up
On the road its sorted - loads of room
But will a 705 sit nicely on an 80mm stem if anyones using it?
Posted : 10/04/2010 9:56 pm
 igm
Don't know but a Garmin Edge 500 does and it does OS co-ordinates(!) which I wasn't expecting
Posted : 10/04/2010 10:52 pm
705 is almost the same size as the Dakota I think, just slimer, and that fits my 80mm stem fine..
[url= http://farm5.static.flickr.com/4058/4446394726_69b3478611.jp g" target="_blank">http://farm5.static.flickr.com/4058/4446394726_69b3478611.jp g"/> [/img][/url]
[url= http://farm5.static.flickr.com/4053/4446389278_5ac108dcb7.jp g" target="_blank">http://farm5.static.flickr.com/4053/4446389278_5ac108dcb7.jp g"/> [/img][/url]
Posted : 10/04/2010 11:24 pm
Won't fit on mine, but sits neatly on the bars immediately to the left of my stem.
Posted : 10/04/2010 11:30 pm
 bol
It depends on the stem. The problem, if there is one, will probably be clearance rather than space. If that's the case, all you need to do is find something suitable to pad it out a bit beneath the mount.
Posted : 11/04/2010 5:21 am
 DrP
You'll be fine - it'll sit just above the headset cap and the stem face (probably!)
DrP
Posted : 11/04/2010 5:25 am
Hmm - mine fits perfectly on my Hope, admittedly it's a 100mm but I have it sat high so it's almost over the bars (if that makes sense). The mount raises it over the front plate and bolts so I can't see how it would be a problem - there's a good couple of mm clearance. As above, worse case scenario you'd just need to fashion a shim to raise it that little bit higher...
Posted : 11/04/2010 6:32 am
 beej
Yep, fine on all my bikes (road and MTB) with various stem lengths from 75mm upwards. The stem mount has a rubber wedge to get the angle right, and this raises it up enough to clear the stem cap and the front of the stem too.
Posted : 11/04/2010 7:09 am
