Freehub identificat...
[Closed] Freehub identification help
2 Users
Can anyone help me identify this freehub type (photos in link below) and confirm what I'd need to buy to replace it please? it attaches to the hub using a 12mm hollow bolt from the non-driveside. Its from a Stout hub with a 10 speed SRAM cassette.
Photos of freehub
Thanks!
Posted : 01/03/2021 9:03 am
It looks very like a FH-04 free hub I just bought to fix a neighbours bike. The only difference is that the hollow bolt is 11mm in that one.
I did a quick search on Cannondalespares to see what comes up, and I think the link below should show a couple. If it doesn’t, just search fh04 on their site.
https://www.cannondalespares.com/search.php?k_m=Fh04
From my research it looks like they’re all rebranded Formula Hubs used as OEM.
Hope that’s of some help
Posted : 01/03/2021 9:15 am
When I was looking it appeared the older versions of the hub used the 12mm bolt but the newer might be 11mm. I suppose the outer part might be the same, and it might just be the Allen Key fitting which has changed size.
Posted : 01/03/2021 9:18 am
Hey dlabz - very helpful, thanks very much!
Posted : 01/03/2021 9:19 am
