Fox Float RP23 - Ho...
[Closed] Fox Float RP23 - How tough?
I'm thinking of getting a Ghost AMR 5900 that comes with a Fox Float RP23 rear shock. My concern is that i weigh over 16 stone and ride aggresivly with a lot of big jumps / drop offs meaning the rear shock is going to take an absolute pounding - is there any history of these failing under heavy use or am i worrying about nothing?
Posted : 09/11/2010 10:33 am
If you're going to be bottoming out a lot, you can get a Push 'big hit' kit which is basically a big elastomer which ramps up the end stroke:
Posted : 09/11/2010 10:39 am
I think the ghost runs a low leverage ratio on the shock so it dosnt work too hard
Should be ok I reckon
EDIT taken from 18bikes
[i]AMR has a true four-bar suspension design with a 2:1 leverage ratio that yields perfectly balanced travel front and rear. Sealed cartridge bearings at all pivots help too.
[/i]
2.1 leverage ratio, it will be fine
Posted : 09/11/2010 10:46 am
And they run needle bearings on the top shock pivot, they look nice too...
Posted : 09/11/2010 11:06 am
 LoCo
Pretty reliable, as long as you keep up with you air sleeve maintaince and get a full service on time.
See how you get on with it before going for a tune or change the shock for a coil unit.
Posted : 09/11/2010 11:08 am
Our RP23 on the back of the tandem runs at almost the max 300psi, with 2 of us (significantly more than 16 stone) jumping up and down on it. No issues at all ๐Ÿ™‚
Posted : 10/11/2010 1:30 am
I weigh more than the op and never had any issues with rp23's. Not even close...
Posted : 10/11/2010 6:29 am
