Fox 34 on stumpjump...
[Closed] Fox 34 on stumpjumper Evo
[#4976048]
Hi,
I want to put Fox 34 forks on my stumpjumper Evo for a bit more stiffness. I notice they are 160mm but I only want 150mm. Is it as simple as just dialling them down to 150mm? I dont want to put more strain on the frame. Is there anything else I need to take into consideration?
Posted : 19/03/2013 1:00 pm
Mojo will reduce them for you
Posted : 19/03/2013 1:01 pm
I'm sure they will be fine at 160, I want a Stumpy to put my 160mm Lyriks on and have been told by a Specialized mechanic that the frame is more than strong enough.
Posted : 19/03/2013 1:56 pm
It may be more than strong enough but the warranty says no more than 150mm
Posted : 19/03/2013 2:13 pm
I've also been looking at a set of these for my stumpy FSR Carbon Comp, the Talas come with an adjustable dial on the top so you can wind them down to your desired height (120mm-160mm adjust).
Think the basic version is an internal adjustmenent only but as stated that would be done by Mojo
Posted : 19/03/2013 2:24 pm
tomaso - Member
So if it breaks strip it down before taking it in and tell them thats what you were riding it at.
Posted : 19/03/2013 2:28 pm
160mm Lyriks on Kevins
Posted : 19/03/2013 5:07 pm
Isn't the 34 pretty much the same length at 160mm as a 32 is at 150mm?
Posted : 19/03/2013 5:20 pm
That tracy is a very similar build to what I want. How does he find it? Much lighter than the 06 Enduro?
Posted : 19/03/2013 5:38 pm
Lighter than his old Enduro, alot lighter than his old SX Trail. Not sure what he will take to the Alps yet.
Posted : 19/03/2013 5:48 pm
