For all the owners ...
[Closed] For all the owners of the Brand X droppers, the Bonty trigger is a great upgrade
Posted this in on wrong forum earlier and it can't be moved unfortunately. So......
I nicked these pics…. But it shows one of this triggers best features, the cable is clamped at the trigger end meaning you fit the grub screw “barrel” at the post end and do the adjusting at the trigger end.
So much easier and the trigger is much better made than the workable but wobbly oem one.
£17.50 too, so not daft money like some after market levers….So suites the “budget but great” ethos of the Brand X dropper perfectly. 😃
Posted : 06/03/2018 12:43 am
I drilled out my grub screw barrel with a 4.5mm bit & fit the cable nipple that end.
Also put a bit of skateboard deck tape on the lever for added grip.
I like it.
Posted : 06/03/2018 2:15 am
I remember you saying that mate. Actually, you might have been the first to try the bonty lever on the Brand X?
I decided to just leave the grub/barrel be and just cut the barrel of the end of the cable so there is nothing at either end and use the little grub screw/barrel as normal.
That might change if I ever drop the tiny grub screw in the future! Lol
Not tried the lever in anger yet, but might dremel a few holes, or score into the lever if it slips on my thumb. We shall see. The skateboard tape is a cunning idea though.
Posted : 06/03/2018 2:58 am
I run a Specialized Command IRRC dropper lever on my Brand X dropper
Works perfectly and like you say isn't as wobbly as the Brand X one
I like the idea of being able to set the cable up at the lever end rather than on the bottom of the dropper post
Posted : 06/03/2018 5:50 am
 DrP
THe Bonty lever is also ‘infinity plus one’ times better than the KS lever!!!
DrP
Posted : 06/03/2018 7:51 am
Good post. I’ve been looking at one of those Wolf Tooth (?) remotes for my Pro, but at £17 it’s a no brainer.
Is it I-Spec?
Posted : 06/03/2018 8:20 am
No bud, just has a hinged clamp. Would need major surgery for match maker/ I spec etc.
Posted : 06/03/2018 8:22 am
I went to order one at triton cycles and they are charging £10 delivery,anyone know of any other places.
Posted : 06/03/2018 12:06 pm
I got mine from triton, didn't charge that much I'm sure....I'll go check....
Posted : 06/03/2018 12:13 pm
Turns out I got it from:
https://www.pedalon.co.uk/acatalog/bontrager-drop-line-under-bar-lever.html#aW532879
But they are oos at the moment. Checked eBay in case a shop is selling on there without the daft postage?
Posted : 06/03/2018 12:17 pm
Best I can find, in stock, is £23 posted from bike24.
Posted : 06/03/2018 12:24 pm
Anyone want to confirm if there saying the brand-x ascent 1x lever is wobbly or are you talking about the 2x/3x version? As my 1x lever is fine but due to it clashing with the left hand control (nice choice of kit by the manufacturer) I need to change it to a 2x/3x version.
Posted : 06/03/2018 12:30 pm
The race face/Easton lever is very nice as well. CRC did have them cheap but think they're all gone now.
Posted : 06/03/2018 12:46 pm
I run the Bonty one with my KS lever, much niver than the KS thumby thing it came with. Haven't done the grip on the levers yet, but may try that as it is very smooth
Posted : 06/03/2018 12:49 pm
My mistake guys I had to change the delivery box to UK mainland £3.95
Posted : 06/03/2018 1:23 pm
Just looked on Triton and the 1x lever is only £3.95 p&p for mainland UK.
As for the original BX lever, there was a bit of play in it just this side of acceptable, but I found the clamp/pivot bolt was made of the same cheese as alloy nipples and rounded easily.  This was also acceptable when I was on Hope Tech Evo levers as I bodged it to the Shimano shifter adaptor.  However, when I got Tech 3 E4's I had to go back to the original BX clamp.
Posted : 06/03/2018 1:35 pm
Would this work with the Giant connect dropper post?
Posted : 06/03/2018 3:02 pm
As long as it's cable pull it should work fine.
You just might terminate the cable at a different end but that is part of the appeal of this lever.
You can adjust the cable at the bar end, rather than the dropper.
Posted : 06/03/2018 3:12 pm
I use the Easton lever, works brilliantly.
Posted : 06/03/2018 3:24 pm
Does anyone do one for bikes that have a front shifter??
Posted : 06/03/2018 5:07 pm
who the hell has a front shifter lol
in all seriousness the bonty isn't that great over the std 1x brand x .yes its cheap but also feels it .the wolftooth is stupid money but then I have stupid money to spend and its just in another league so horses for corses
Posted : 06/03/2018 6:09 pm
The thing is, the XL dropper cost me £92 after bc discount so spending half of that again just on a shifter makes no real sense.
In all honesty, the bonty shifter is more than good enough and I'm impressed with it for the money. 🙂
Posted : 06/03/2018 7:34 pm
How much of an issue is it fitting the Brand-X 1x lever and Shimamo brakes?
Where does it foul?
Waiting for my post to turn up and trying to decide whether to try the Brand-X lever or just go straight to a SouthPaw or something else.
Are Wolftooth the only ones who do an i-spec b compatible lever?
Posted : 06/03/2018 8:05 pm
Remember the south paw still has you doing the adjusting at the dropper end. One of the main reasons the bonty is worth getting.
The wolftooth does have this advantage too however...but you pay the price.
Posted : 06/03/2018 8:37 pm
Fits the RST dropper with no mods and gets rid of the industrial conduit at the same time!
<span class="aZo a5r aZp"><span id=":mq" class="a3I">Preview attachment IMG_20180307_153023.jpg</span></span>
<div aria-hidden="true">
<div class="aSG"></div>
<div class="aVY aZn">
<div class="aZm"></div>
</div>
<div class="aSH">
<div id=":t7" class="aYv"></div>
<div id=":rz" class="aYy">
<div class="aYA"></div>
<div class="aYz">
<div class="a12">
<div class="aQA"><span id=":vv" class="aV3 a6U">IMG_20180307_153023.jpg</span></div>
<div class="aYp"><span id=":su" class="SaH2Ve">2.1 MB</span></div>
</div>
</div>
</div>
</div>
<div class="aSI">
<div id=":m3" class="aSJ"> <span class="aZo a5r aZp"><span id=":tq" class="a3I">Preview attachment IMG_20180307_154452.jpg</span></span>
</div>
<div class="aSH">
<div id=":oa" class="aYv"></div>
<div id=":pj" class="aYy">
<div class="aYz">
<div class="a12">
<div class="aQA"><span id=":mc" class="aV3 a6U">IMG_20180307_154452.jpg</span></div>
<div class="aYp"><span id=":tr" class="SaH2Ve">1.6 MB</span></div>
</div>
</div>
</div>
</div>
<div class="aSI">
<div id=":rv" class="aSJ"></div>
</div>
</div>
</div>
</div>
</div>
Posted : 08/03/2018 10:53 am
And only £17.45 from Pedal On including postage
Posted : 08/03/2018 10:56 am
thanks for the tip just ordered one from pedal on, the easton one that came with my post broke so i replaced it with the brand x one which although it works im just not a fan of. this looks much better , i cant bring myself to pay wolftooth prices
Posted : 08/03/2018 11:16 am
