Fitting a bash guar...
[Closed] Fitting a bash guard to a double M785 chainset
3 Users
Just had a look at fitting a gamut P20 bash to the above and realised that unlike triple chain sets the double has no flat outer face where the bash would sit.
Does that mean it won't work as I'm a bit worried the bash might crack when the bolts are done up tight?
Posted : 19/07/2013 10:23 pm
 JoeG
If the outside face of the crank spider is recessed for the bolt head, would a [url= http://www.wiggle.com/id-chainring-spacers/ ]chainring spacer[/url] work between the bash and spider?
[img] ?w=350&h=350&a=7[/img]
Posted : 20/07/2013 4:25 am
The problem is that the outside edge of the spider is not flat so where the bash sits on the spider it's not a flush fit
Posted : 20/07/2013 7:49 am
Look into a blackspire defender
Posted : 20/07/2013 8:09 am
 JoeG
That's why I'm suggesting the spacers! 🙄 They will hold the bash away from the swoopy spider at 4 points.
Posted : 20/07/2013 8:01 pm
