Shimano Zee brake p...
[Closed] Shimano Zee brake pad split pin
[#5348571]
Does anyone know of any alternatives to using the split pin for the Shimano Zee brake pads?
Posted : 19/07/2013 11:55 pm
you could use it as a walking sticking for a small monkey
Posted : 20/07/2013 12:13 am
What's wrong wi the split pin?, my car uses a split pin (albeit a rather large one) to hold the brake pads in place and i trust that when hooning into a corner at 100mph+.
Posted : 20/07/2013 12:27 am
[quote=somafunk ]What's wrong wi the split pin?, my car uses a split pin (albeit a rather large one) to hold the brake pads in place and i trust that when hooning into a corner at 100mph+.
They add pliers to the list of trail tools required to do a pad change?
for alternatives you can use a tiny allen key from a multi tool and a zip tie
Posted : 20/07/2013 12:31 am
Hmm, i've never had to do a mid ride pad change so you've got me on that one, and you don't really need a set of pliers to remove the split pin - anything to lever the bent section will do such as the blunt end of a multi-tool screwdriver or tyre lever will do.
Posted : 20/07/2013 12:40 am
You need these:
http://www.wiggle.co.uk/shimano-br-m785-pad-axle-snap-ring/
Posted : 20/07/2013 6:39 am
Thanks droppinneutron, much appreciated.
Posted : 20/07/2013 11:04 pm
