Fatty crank.
[Closed] Fatty crank.
5 Users
Looking to replace my original fatty crank on my on-one.
It's a good opportunity to drop some weight so what do you recommend ? Race face any good?
Edit- this will be used with a single 30t chainring
Posted : 19/07/2016 7:03 am
Got am aeffect on mine. If you want to go lower than 30T a cinch might be better
Posted : 19/07/2016 7:17 am
I've got SRAM X9 Fat on mine, they're a spider style crank so you can fit tiny rings, I expect got a 28t sram-x-sync steel one.
They're nice looking cranks
Posted : 19/07/2016 7:42 am
Aeffect are good, got them on mine. 24mm means you can can use Shimano BB.
You can use direct mount rings (not sure what RD means about cinch?) or a spider. I've gone for a spider, got 104mm on other bikes, and I swap around SS/ gears from time to time, so matchy-matchy fine for making easier swap times.
Posted : 19/07/2016 8:00 am
rOcKeTdOg - Member
Aeffect ARE cinch interface - I have a 28t on mine
Posted : 19/07/2016 8:06 am
