Exploding ust tyre ...
[Closed] Exploding ust tyre - why?
7 Users
Opened the garage this morning and noticed the Nobby Nic on the whippet had gone bang in the night, distributing latex hither and yon.
This has happened to me once before, also with a NN coincidentally. In that case the tyre wasn't usable afterwards - the bead must have gotten damaged somehow in the blow out as it wouldn't inflate onto the rim.
I didn't have a change to check the one this morning as I was leaving for work - anyone know what's going on here?
ETA The tyre wasn't at a ridiculous pressure or anything - something like 35psi. The rim was a crest and the tyre was a 2.2.
Posted : 20/01/2012 12:45 pm
ghosts...big ones...
Posted : 20/01/2012 12:51 pm
Spiders with a taste for rubber and sealant?
Posted : 20/01/2012 12:56 pm
Your lucky, mine went off and I ended up covered with jizz whilst I was bent over pumping*... as well as being deaf for most of the day...
*I dont like double entendres as a rule, but I'll slip one in occasionally
Posted : 20/01/2012 1:04 pm
I'll bet you will.
Presumably just using yellow tape? It does tend to knacker the bead when that happens, but I wonder if the bead fails (at least partially) then the tyre blows off, rather than vice versa.
Posted : 20/01/2012 1:23 pm
Sounds like a failed bead to me, I've had this happen a few times. One memorable time it took the sidewall of a 719 rim with it.
Posted : 20/01/2012 1:29 pm
Thks - I guess it makes sense that the bead is failing causing the blow-off. Have to say I don't understand why a tyre bead would suddenly fail like this; must have been a bad one from Schwalbe.
Posted : 20/01/2012 1:36 pm
You bought Schwalbes.
Posted : 20/01/2012 1:42 pm
