Elixir 1 Pads
[Closed] Elixir 1 Pads
Does anyone know if Avid Elixir 1 brakes take the standard Avid Elixir pad?
Thanks
Posted : 08/11/2013 11:58 am
 cp
they do
Posted : 08/11/2013 12:03 pm
yep. elixir pads are elixir pads are elixir pads....
Posted : 08/11/2013 12:21 pm
 JoeG
Pads are the same, but the Elixir 1s use a cotter pin to retain the pad. Other Elixirs use a special bolt and circlip. Both systems come with Avid brand replacement pads.
I tapped my Elixir 1s to use the bolt like the others.
Posted : 08/11/2013 7:58 pm
It's a split pin, a cotter pin is tapered and was used to hold cranks on the more traditional sit up and beg bikes.
(Oh help, I'm turning into the sprocket and cog man)
Posted : 08/11/2013 11:43 pm
Have seen a few odd oe fitments that had a lever saying elixir but Useing the older juicy caliper
But if the caliper says elixir then you should be fine
Looking a few online pics of the pads will confirm what you have
Odd you should mention cotter pins I've spent a big chunk of my afternoon trying to remove one
Posted : 08/11/2013 11:51 pm
 JoeG
benji - I'm American, so I call it a cotter pin. Ask for a split pin over here, and no one will know what you're talking about.
I didn't even realize that there was another term used at all till I looked on wikipedia...
Posted : 09/11/2013 12:47 am
