Edge GPS - how do i...
[Closed] Edge GPS - how do i add 8x waypoints?
3 Users
i've got 8x OS grid references for an event this weekend. i'd like to put them into my Edge 800 so i can see where they are. how can i do that?
Posted : 08/01/2018 8:24 pm
Use Garmin BaseCamp:
Make a new folder, add the 8 references (use the flag icon), tidy up the naming, when done select the folder and from "file" menu choose Export "folder name" and you will have a GPX file.
You can copy this over to the "New Files" folder on your Garmin 800 as you would a route.
Posted : 08/01/2018 10:04 pm
Try saving your route with waypoints as a tcx. I think it has worked for my 800 in the past.
Then copy into the \newfiles folder on the 800
Posted : 08/01/2018 10:10 pm
thanks for responses. managed to work it out. using bikehike.co.uk created route, added 8x coursepoints (manually/visually placed the OS grid references), saved to .tcx and copied to \newfiles folder on 800. works well.
Posted : 08/01/2018 10:23 pm
