Ebike advice for th...
Ebike advice for the larger gentleman
 xora
How large is large, I am 116kgs and not massively fit. I ride a Levo SL mainly for the reason a lot of routes around here involve locked gates and I can lift it one handed over them without much effort.
I have the range extender for longer rides. I would estimate at my weight spending most of the ride in the lowest 2 levels of assistance that it will easilly do 80kms on a single charge!
Posted : 15/03/2024 5:45 pm
But given the ebike is probably twice the weight of a regular bike, maybe the 18% is just negating that extra weight
Pedalling the 50lb+ 180mm tank with 2.8 beefy tyres @ 18% = easier than 32lb 150mm HT on fast 2.4 tyres
15% on the ebike and your legs are starting to work more - I'd say down to 10% and you are probably making it feel like a normal big bike
Posted : 15/03/2024 7:24 pm
I’d say down to 10% and you are probably making it feel like a normal big bike
Even with the assistance set at whatever theoretically will give you the same workout as a manual bike it still doesn't feel like a manual bike.
If you're turning the power down that much it's more fun on a manual.
Just take it for what it is.
It's not meant to feel the same.
That's just pointless.
Posted : 15/03/2024 9:36 pm
Even with the assistance set at whatever theoretically will give you the same workout as a manual bike it still doesn’t feel like a manual bike.
If you’re turning the power down that much it’s more fun on a manual.
It’s not meant to feel the same.
That’s just pointless.
I've been riding an ebike for almost 6 years, MTB's for over 30 years and bikes in general for well over 40 years. I know what feels like what and what's fun 😉
But - yes, you're right, it never feels exactly like a normal bike
I've used it once properly turned down (can't remember exactly what level of assist) to do a 46 mile / 5000ft ride - 504Wh battery on old tech - managed to get 29 miles out of the first battery. Was less frugal with the second battery and used a good chunk of it on the remaining 17 miles.
The thing with ebikes though is that whatever assist level you choose, you aren't stuck with it - so even on a low eco setting, there were times when it got stuck in trail and turbo, depending on the terrain.
Nothing is pointless if you're doing it for a reason. Everyone has different requirements at different times - what's good for you might not be good for someone else. Buying an ebike and constantly having it turned down to a barely noticable level would be a bit daft though
Posted : 15/03/2024 9:53 pm
Only 6 ,30 and 40.🤣
I can beat you on all of them if you want a dick swinging contest.☹️
Still doesn't change the fact a turned down eeb doesn't "feels" the same as a big bike.
It feels totally different.
Both bike are much better riding them how they were intended.
They're both great fun and a great tool but a turned down eeb is ultimate defeating the point of what it's for.
I almost got put off eebs by the dismal performance of my mk 1 Kenevo.
As for carrying an extra Kenevo MK1 battery that has to be the ultimate way to kill the fun of a ride and two batteries to do just over 1500 meters is a joke.
Each to the own though.
Back to my original advice to the OP
Test both.
It's a lot of money to spunk on what folks you don't know say on a forum...
Posted : 15/03/2024 10:13 pm
Sam's bikes is a reasonably objective place to start
Posted : 15/03/2024 10:15 pm
Or robs Rides. More the UK orientated rider.
https://www.youtube.com/@RobRidesEMTB/videos
And an interesting vid on lightweights.
But I think it should be noted, especially where range comes into it, that you are going to get more miles on a lightweight, if you yourself are lightweight, rather than someone thats maybe riding the same lightweight bike but weighs 14 stone.
That said, I think if you are a skilled experienced rider, the lightweight is going to suit better, and with a range extender the total available range is going to make up for the lack of full fatness.
Probably a case of the best of both worlds, but only if you are the type of rider who is up to it.
Us old fatties need not apply 😆
Posted : 16/03/2024 3:10 pm
Page 2 / 2
