http://www.industrialcoatingsupplies.co.uk/
Saw examples of their work on more 'industrial' parts that they did for a mate at the w/e. Finish quality was very good and the price was keen too.
not used them, but I have used these guys in Exeter:
[url= http://www.1stchoicefinishes.co.uk/ ]http://www.1stchoicefinishes.co.uk/[/url]
For powdercoating both Alu and steel. Finish was pretty good, cost about £40 for a frame, finsih on the steel frame was better than the Alu one, but both were still better than soem I've used in the past who charged a lot more.
pics of the steel frame here:
[url= http://www.retrobike.co.uk/forum/viewtopic.php?t=87450&postdays=0&postorder=asc&start=15 ]Bontrager Privateer[/url]
Only reason I'd consider using them is that they are a stones-throw from my parents and, as I seem to be down there fairly regularly at the moment for family/work, if the price and quality was right it would be no hardship to use them, even though they're ~70 miles from home, compared to the usual suspects around here!
If its an aluminium alloy frame then go to [url= http://www.revillspaint.co.uk/ ]Revill[/url] for 2 pack paint spraying, excellent quality, at Exeter airport business park.
Yep, alu frame. Powder coating appeals for the durability and cost (its for a commuting frame, so the maximum durability I can achieve for the minimum cost!!!). Airport is a posibility, seem to be falling off the end of the M5 most weeks at the moment......
which frame is it?
Toys - Its an old alu Airbourne Carpe Diem 700c frame..... pretty sure it's 7000 series alloy, but would need to check.
Neil - that was done by ICS was it? How much, and did they know their onions when you handed then a frame?
bristolbiker - yep, done by ICS. The fella seemed to know his stuff, he had a few frames under the counter to show me the type of finish i could expect.
We talked about the prep-process and masking off. So all good really.
There are 2 prices IRRC, hardtails £30 and full sus'ers that require a lot of masking / gentle prep £60.
HTH.
Top stuff fella - thanks 🙂
Neil, does that include stripping the frame of all previous coatings?
...actually, that's a good Q - did they do the masking as well?
Ideally, I'd just like to drop off the frame, complete with its current shabby paint, tell them where to mask and come back a week later to pick up the shiney finished article.
Could do with some of the cable bosses moving/removing as well, but that's another story......
sharki, bristolbiker - yes it does... the cheeper' of the 2 prices is for a hardtail and the 2nd is for a full susser where there is more prep work.
£60 to strip, mask and paint. I did have to go over a few bits with a Stanley blade tho.
I have used them to do a couple of alloy multi finned rads they stripped them and coated them really well infact they look better than new.
That reminds me I must drop my Kaffenback off there for a respray
