Dynamos. Talk to me...
[Closed] Dynamos. Talk to me.....
After a recent trip to Belgium I've become convinced that dynamos are the way foreword. I was fairly sure before this, but seeing virtually every bike fitted with one convinced me.
Now, I want something to charge stuff whilst we're touring too and a bit of digging found this little beauty:
http://www.bike-discount.de/en/buy/busch-mueller-lumotec-iq2-luxos-u-led-headlight-63073/wg_id-1402
Which fits the bill perfectly. If you read the specs and reviews it's an amazing bit of kit
I also fancy the SP/Exposure dynamo. I've built one up before and it's spot on, small and unobtrusive with no drag that I could detect.
So the question is - Can I simply plug any light into any dynamo, specifically these two?
Posted : 19/02/2015 1:15 pm
According to this page - http://blog.dutchbikebits.com/2012/01/selecting-and-installing-dynamo.html - all dynamo hubs and lighting systems are compatible, there may be some dynamos that only output 2.4W which are suitable for front lights only.
Other than cost I don't know why more people don't go for a dynamo hub system. The drag is negligible, see the Myths section here http://robdeanhove.blogspot.mx/2012/07/racing-on-dynamo-charging-my-gps-bright.html, it's almost a fit and forget setup and you can't run out of batteries!
Edit: I need to add a GPS/phone charger extension to mine 🙂
Posted : 19/02/2015 1:27 pm
Could be their frequent inability to respond to email (always better to phone IMO) but I mailed Exposure a year or so ago to ask about compatibility between their dynamo equipment and other manufacturers'. I have/had a Shimano dynamo hub with B&M front and wanted to either run a redeye from the B&M lamp or know if the Shimano hub would drive a Revo plus redeye.
Tumbleweeds ensued so I stuck with the B&M gear. At a guess I'd say that the dynamo hub will output enough power but it probably has some proprietary connecting gubbins.
Posted : 19/02/2015 1:47 pm
Don't your lights go out when you stop moving though? Not great if you are waiting to turn right for example.
Posted : 19/02/2015 1:48 pm
No, they have a stand light, probably a capacitor of some kind to provide the power. Depending on the model this can be anywhere from four to ten minutes. On mine (B&M Cyo) the light dims slightly and stays lit for about five minutes
Posted : 19/02/2015 1:56 pm
I run a few B&M lights and the Exposure Revo. All work well with either SP, Exposure (SP rebranded) or Shimano hubs. Shimano hubs put put a little more current at low speed ive found, but you only barely notice when setting off at a start of a ride, no difference after 10meters. No noticable difference in drag either.
B&M lights are much better than the REVO on the road (better beam shape = more light on the road, so noticeably brighter, but obviously not so good offroad due to beam pattern.
Posted : 19/02/2015 2:02 pm
Station, thanks very much that's very good info there. I can get the whole set up for about £143 which seems like something of a bargain 🙂
Posted : 19/02/2015 2:05 pm
[i]Dynamos. Talk to me.....
[/i]
That's nothing; I see dead people.
Posted : 19/02/2015 2:06 pm
 DrP
Is that the sp hub, and light, for £143 Pete?
DrP
Posted : 19/02/2015 2:35 pm
I have SP dynamos on two bikes with REVO exposure lights and a redeye rear, have done so for over a year now and wouldn't go back to a battery and they stay on when you stop.
Posted : 19/02/2015 2:52 pm
This is really funny
Posted : 19/02/2015 3:42 pm
I am also interested in this. Are they suitable for a commuter? By that I mean can you leave the lights on the bike when it's locked up and not worry about them getting nicked?
Posted : 19/02/2015 3:44 pm
My light comes off via a quick release system which allows me to use it as a torch when away bike packing but I guess the wheel would be attractive to anyone who spots the wires and knows what they are looking at?
Posted : 19/02/2015 3:57 pm
I've got a dynamo front light on my commuter, it's mounted via a bolt through the fork crown (apparently this is the ideal height for the particular series (B&M)). I suppose if someone really wanted to nick it then it's not that hard to get off.
The only problem I've had is people "helpfully" turning the light off to save my battery after I've walked away and the standlight is still in operation 😆
Posted : 19/02/2015 3:59 pm
I've had a Revo, exposure hub and a redeye for about 18 months now. It's been brilliant (sorry - IGMC)
I do a lot of adventure racing, and have found that the dynamo solution is great for multi-day races because you don't have to worry about the batteries. (It's very rare to be able to charge batteries during an expedition race, so you either run everything on low power and eat carrots, or use a light that has replaceable batteries). The hub seems to be fairly bulletproof as well - mine has been dragged through mangrove swamps, knee-deep mud and ridden down a hub-deep river for 90 minutes (Wales, apocalyptic rain turned a stream into something rather bigger!). It's shown no signs of needing a service yet, which means that it survived better than the bottom bracket did...
Coupled with a joystick in a helmet mount (for hike-a-bike, control finding and map-reading) it's the perfect solution for my needs. I've added a Kemo M172N USB charger (from Maplin) and this allows me to charge the Joystick from the dynamo when riding during the day, ready for use at night.
Highly recommended - to the point that I'll be getting another hub so that I can run the revo on the commuter bike. Any hub will work with any light, just make sure the hub is rated at 6v 3W if you want the most power. Some of the cheaper shimano hubs are only rated at 1.5W or 2.4W so the light won't be as bright if you use them.
Posted : 19/02/2015 5:15 pm
I was wondering about this. It seems like some of the pricier ones are available in les than 3v as well, like the Shimano XT comes in both 1.5v and 3v guises. Does anybody know the differences, apart from less weight? How much dimmer will your lights be?
Posted : 19/02/2015 5:25 pm
 DT78
I'm interested in this too, £143 all in sounds a good deal...I'm interested too.
bike-discount had some fairly heavily discounted wheelsets with shimano dynamos and mid range mavics, but they seemed to weigh a lot. Not sure I want to spin that sort of weight for several hours.
Posted : 19/02/2015 5:30 pm
sounds too low a price to me: SJS cycles have the SP dynamo hub (15mm axle) version at £149.99 the light is £80 or so (not sure of the exchange rate from Euros)
Posted : 19/02/2015 5:40 pm
Spa Cycles in Harrogate were doing deals on dynamo set ups a few weeks ago - also offered deals for CTC members iirc.
Lack of funds prevented me having a go at it.
Posted : 19/02/2015 5:42 pm
The Shimano 1.5v will not power the Luxos. IMHO as a once retailer they are a pointless aim to hit a pricepoint. The industry went for a 3V standard for a reason so customers knew where they stood. </rant>
Have a good read of the spec's on the Luxos and the E-Werk as they do slightly different things and it depends what you want to prioritise.
The Luxos "The integrated buffer battery that supplies the charging current not only has the task of supplying the USB port. It also powers the flood and parking light functions. To fully charge the backup battery, you require 20 minutes at a speed above 17 km/h without a USB device connected and with lights switched off. The Luxos is then optimally prepared for operating/charging a USB device within its capabilities"
Posted : 19/02/2015 5:45 pm
Does this mean that they are ok for lights that don't have a USB charging port?
Posted : 19/02/2015 6:09 pm
DrP, yes, but I can get trade price on the Dynamo remeber!
The light is just over £80 from one of the Bike-discount.de which is about £10 less than trade believe it or not!
After reading the Dutch Bike link above I wouldn't bother with a 1.5w Dynamo at all, not that I was considering one anyway.
The B&M light is simply good value when you look at the other USB options like The Plug which costs more.....
If you go looking at the spec and beam pattern shots it looks fantastic. Auto on:off with daytime running lights, switchable high beam, monitoring of a rear light and of course the USB port.
Posted : 19/02/2015 6:49 pm
It will be. It's the same reflector and output as the SON Edelux II I've found to be really great light for road use. So much better than the round beam output lights I used before. I use it with an SP hub and separate USB-Werk charger, mainly as I wanted to be able to use the charger in a frame or bar bag. I did read of some issues with sealing quality on the B+M light but there's a negative review of pretty much anything if you look for long and I suspect my extended cables and joins are equally likely to cause issues long-term.
Posted : 19/02/2015 7:16 pm
I've posted this link quite a few times regarding my set-up on the Tripster thread but it's worth posting here again, there's lots of good info throughout the site regarding dynamo hubs/wiring as well.
[url= http://www.peterwhitecycles.com/headlights.asp ]Link to peterwhitecyles headlight beams[/url]
Posted : 19/02/2015 7:47 pm
Soma, yes I was just logging on to post that exact link (So I will, I've copied, so I'll paste.... http://www.peterwhitecycles.com/headlights.asp) as it's very informative
I like this bit
[i]At low speeds a hub dynamo has less power available. So the Luxos U reduces the power to the primary LED and sends the remaining power to two other LEDs which project light close to the bike and to each side. This happens automatically, and gradually. In other words, there isn't a speed above which the distance beam is on, and just below that the near beam switches on. Oh no. At about 15kph, as you go slower, the distant beam gradually dims, while the near beam gradually increases. It's a very smooth transition as your speed changes.[/i]
So it changes its beam to brighter-closer as you slow down and brighter-further as you speed up!
Posted : 19/02/2015 9:19 pm
I've been running dynamos for decades - so apologise now if some of my knowledge is out of date.
Some dynamos only kick out 2.4W but a friendly expert said that with modern LED lights it makes no odds.
The SON kicks out more watts at higher speeds and can be set up so that you switch on a second front lamp when you need it with faster travel. The Shimano ones can't do this.
This review is a bit old (2012) but gives you some technical background.
Posted : 19/02/2015 9:36 pm
 kcr
The only thing that put me off the SP dynamos was the potential hassle of servicing. I've had sealed bearings that have lasted for ages, and others that have failed fairly quickly. That's not a problem if I can knock them out and press a new set in myself, but with the SP you have to send the hub off to the manufacturer to be serviced, which involves removing the rim and spokes and then rebuilding.
I want a dynamo for year round commuting use, which will get a bit of abuse in the winter, so I have decided to go with Shimano, because at least I can squirt some fresh grease into the bearings now and again.
There are so many different models of B+M lights, and so many variants of each model that it's quite confusing trying to work out what's available.
As far as I can make out, the latest ones with the best beam patterns and biggest outputs are the Luxos (USB and non USB variants) and the IQ Cyo [b]Premium[/b], which is available with R reflector, T daytime running and RT variants (and just to confuse things more, those variants have different light outputs and near vs far field illumination patterns). There are umpteen other models and variants further down the range.
The Peter White page is very useful for a clearer comparison.
Posted : 19/02/2015 10:04 pm
I bought an SP dynamo wheel from Spa a few weeks ago for £125 and a Luxos U from ze Garmans for €110. A couple of years ago, I managed to snag a Shimano n80 hubbed wheel for £60 and a Cyo lamp for ~£35 from Rose. Both set ups are ace and pretty good value 🙂
Posted : 19/02/2015 10:19 pm
No one using the modern Sturmey-Archer?
Posted : 20/02/2015 1:59 am
Have you seen that light in person PP? It's a great big lump of a thing, if these things bother you.
Posted : 20/02/2015 8:16 am
Just phone St John Street Cycles. Very knowledgeable bunch when it comes to Dynamo lighting, but in answer to your question, you can pretty much run any light from any hub.
I run SON hubs on 2 bikes and they are superb.
SON Edelux light on the road bike and Supernova E3 Triple on the mountain bike. Again, both superb.
If you want Dynamo front and rear, I can highly recommend the Supernova. You run the rear light from the front in series.
Otherwise, you just need to trim and insulate the rear wire that is factory fitted to the front light.
Well done on the dynamo choice. They are an amazing piece of kit. Having light on tap is brilliant, and no battery packs dancing from the bike that you have the remember to charge is a huge advantage. I pretty much run mine all of the time now, even in the daylight. The hubs really don't drag at all, and better safe than sorry.
Posted : 20/02/2015 8:21 am
 DrP
Oooh, the PD 8 is £80 from spa cycles...
If only I could find another kinesis CX rim to build one up..
DrP
Posted : 20/02/2015 10:39 am
With a Kemo M172 fitted I can now run my Garmin GPS during the day without using battery power and recharge it in situ if, for any reason, I've had to switch the lights on.
Posted : 20/02/2015 10:47 am
From an SP distributor - "They will replace for free within 2 years, OR charge you US$30 (after 2yr are up) for the bearings, fit them for you, and pay for return postage."
I think you can send the whole wheel but may be wrong. Considering the mileage some riders have on an SP hub in a year (inc off-road use) I'm not worried about the hub bearings. Not heard any reports of early failure yet.
Posted : 20/02/2015 10:54 am
That CTC article is amazingly useful. It also seems to be suggesting that 1.5v would be fine for an LED lamp, and would cut the drag in half (with lights on)
Posted : 20/02/2015 11:50 am
More useful reading on dyno outputs. Suggests that a 20" wheel hub is a better option than a 1.5 if you want minimal watt losses into the hub, I think. ie 2.7W from a standard hub at 15kph to meet German regs for town use but many riders will average more than that so the 20" hub has less drag and outputs enough at 20-25kph. The drag of a normal SP or SON isn't worth worrying about ime, maybe if it really matters to you it'll depend on how long your regular climbs are and whether you can accept the output drop then.
Posted : 20/02/2015 11:57 am
I get the feeling a lot of people worry about drag but I think modern dynamo hubs barely drag at all, and most reports I've seen on the net have said it's not noticeable at all.
I think we all have worries they are going to feel like one of those old-fashioned bottle dynamos that run on the tyre!
Posted : 20/02/2015 2:40 pm
That Kemo USB module looks like a good idea....
http://www.maplin.co.uk/p/kemo-bicycle-power-charge-controller-usb-n18dd
Posted : 20/02/2015 2:42 pm
I've built an Exposure Dynamo hub up. Once it's in a bike you can't feel it at all.
Which I used for years and years in the 80s and it never bothered me then. 🙂
Posted : 22/02/2015 12:51 pm
 DrP
I've just ordered the light PP linked to... need to source the Hub (Will go for SP) and a rim.
I'll be using it on my work bike, but also to swap to the Tripster for little tours etc etc.
I love the USB charging idea!
Pete...hubs... 😉
DrP
Posted : 24/02/2015 6:05 pm
The Kemo unit is good, but quite large! Also, ensure that you get the M172N, not the plain vanilla M172, as the cheaper one won't put out enough current to charge a modern smartphone.
Regarding drag, it's not noticable. Honest.
Posted : 24/02/2015 6:38 pm
Come on Jameso - kick Evans into some action with this one! Please 🙂
There is a massive (and slightly confusing) choice of dynamo hubs and lights in Europe - why not simplify things for us all, choose just one or two good combinations and start stocking them as a package.
And what is frankly ridiculous - Evans (and everyone else) sells squillions of different lights yet I can't walk into a store and buy a single one that is UK road legal. Lights to the German regs would at least be a legal(ish) alternative.
Posted : 24/02/2015 6:57 pm
@mick_r UK regs allow for lights that pass equivalent (or better) European regs as legal in this country. So the German road lights are legal here.
I don't know how much it costs to get a light through the relevant British Standard but I suspect it is high enough and a lengthy enough process that most manufacturers won't bother for such a small market.
Having say three dynamos and three lights to cover various price points should be enough as stock. I've seen one retailer (US based I think) who just stock one dynamo.
Look at somewhere like Spa Cycles: 16 dynamo models some in 32 & 36 hole versions, some disc compatible; different colours, etc. Then they have eight front lights to go with them.
Posted : 24/02/2015 7:12 pm
My light and dynamo arrived today. Just gotta find time to build the wheel......
Posted : 24/02/2015 8:30 pm
I got a hub/light package from Evans 14 months ago.
Pay attention at the back.
Very happy with it too.
Posted : 24/02/2015 10:17 pm
Sounds good, what was it?
Posted : 24/02/2015 10:24 pm
Pretty sure Evans stock Exposure Dynamo hub/lights...
Posted : 24/02/2015 10:26 pm
The 1.5v dynamo is half the power of the 3v Half of what the industry build their equipment to run on. You will not get the advertised performance
Posted : 27/02/2015 10:18 am
I think its 1.5w rather than 1.5v? I would imagine its powerful enough to run some low power "be seen" type LED dynamo lights, but I've not found anyone who's actually tested this.
Would be a good cheap lightweight setup for my commuter which often gets locked up outside
Posted : 27/02/2015 10:53 am
I have an Alfine 1.5W hub I intended to try out but tbh all the data suggests it's not worth the bother compared to a similar cost 3W hub. I think a micro-dyno Dura-Ace hub would be cool to power DI2 and top up a Garmin though.
mickr - I'm not involved with P+A so it's not my call. I agree though. I have german-legal F+R lights on a road bike and I bought one from SJS, the other from Bikediscount.de. Very happy with them, my perception is that drivers are too, based on space given and general interaction with traffic at night. But I'm in the minority of riders that think stobing, unfiltered and direct-beam lights aren't good for the unlit roads where I ride at night, a bit different in cities where something stolen off a U2 lighting rig may make more sense.
Posted : 27/02/2015 11:06 am
So far my research into the fairly complex world of B + M lighting choices has suggested the following to conclusions (correct me if I'm wrong)
The 'R' stands for 'reflector', which is built in to the lense itself
The 'T' stands for 'daylight', which I [i]think[/i] means it has additional LEDs that run seperately from the main LED for daytime use.
everything else is still a mystery...
Posted : 27/02/2015 11:13 am
Ok further reading has revealed thus:
'Senso' means the main light comes on automatically at dusk or night
'N' is the absence of the above
'B' just means 'basic'
'Plus' means that there is a compacitor powered stand light, so it will shine for up to four minutes after the bike has stopped
'U' I [i]think[/i] this means it has a bar mounted on/off switch with a USB charging socket
Posted : 27/02/2015 11:35 am
Shameless plug for my 29er Dynamo wheel in the classifieds http://singletrackworld.com/forum/topic/29er-dynamo-front-wheel-like-new
PD8 Hub
Was used with the Luxos U light, which I have moved to the road bike with another PD8 hub. Great combination. I don't switch is off during the day anymore as I can't even tell its on. recently done a couple of 200km audax's and it have been great.
Posted : 27/02/2015 12:01 pm
I was paying attention:-
The Exposure light is very, very nice, but not road legal....
Cheers James - any chance you could send this link to your P&A people? Surely it is a niche in the market worth exploiting (the only drawback being admittance that all those other lights aren't legal....)
Posted : 27/02/2015 1:47 pm
My bro (peterpoddy) just sent me this picture of the Exposure hub he is building up for me, compared with a Shimano M525 disc hub - can't believe it's smaller!! he has weighed it at 180g more than the Shimano hub.
[URL= http://i410.photobucket.com/albums/pp187/rcatkin/Bikes/Genesis%20Tour%20De%20Fer/9D737E41-7A08-429F-AC09-4F6208100BC7_zpshd9pbbqj.jp g" target="_blank">http://i410.photobucket.com/albums/pp187/rcatkin/Bikes/Genesis%20Tour%20De%20Fer/9D737E41-7A08-429F-AC09-4F6208100BC7_zpshd9pbbqj.jp g"/> [/IMG][/URL]
Posted : 27/02/2015 2:02 pm
This is interesting, why not? Surely it's bright enough? Too bright, maybe?
Posted : 27/02/2015 2:08 pm
I think I may have answered my own question:
The suggestion that any lamp on a bicycle might cause undue dazzle or discomfort to other users of the road would have been laughable a few years ago, but not any more. It is not only illegal but doesn't actually improve your safety, should the person driving a heavy motor vehicle towards you be temporarily blinded by your headlamp! So please don't let it do that.
[url= http://www.ctc.org.uk/cyclists-library/regulations/lighting-regulations ]CTC website[/url]
Posted : 27/02/2015 2:26 pm
Mick, I'll mention it, there's a few good options from suppliers I think we deal with. The Sigma rear light I got is brilliant, non-dazzling with great visibility angle range - [url= http://www.sigmasport.com/en/produkte/beleuchtung/rueckleuchten/mono_rl/?punkt=features ]Sigma Mono [/url] Doesn't have a flash mode tho so not sure how it would sell over here.
Posted : 27/02/2015 3:47 pm
Cheeky git posting my pics without permission...! 😉
Yep, it's all fitted and working on the Touring Inbred now. I've got another hub for my CdF but I don't have the right length spokes, so that'll be a week or so. There's virtually no detectable drag even just spinning the wheel round on the stand, so I doubt anyone will notice anything out on the road. The B&M light is impressive quality, fits absolutely rock solid and has well thought out wiring and features. I need to get out for a ride once it gets dark to test the lighting capabilities but in the dark garage its obviously a very large pool of light. It doesn't look anything like the round focussed beam of a MTB light though. This is to be expected as its a German approved dipped beam.
You can just see it rock slightly as it comes to rest, but a gentle push has it running for a fair few seconds.
Posted : 27/02/2015 5:44 pm
Looks great! Thanks for the video! What does the light look like?
Posted : 27/02/2015 6:35 pm
Cheers James
That Sigma one looks interesting. I don't think the German manufacturers help the confusion by selling a multitude of similar lights (including some older models that are a bit rubbish).
It is just the ridiculousness of the situation that annoys me - if I went to the shops tomorrow then I can maybe think of one bike shop within a 50 mile radius that sells a legal light (and there are a LOT round here including at least 4 of the big mail order warehouses). Added to that everywhere on the high street (Argos, Wilko, Tesco, Asda etc) also sells non-legal lights (even the cheap leds don't count under the relaxed rules because they invariably have a non flashing mode).
But if a car insurer wanted to get pedantic about a claim (has this ever happened?) then it is the cyclist that looses out. Most people reading this will be OK because we have the inclination to scour the catalogues and websites to find a combo that suits and mail order it from Germany etc. But does it really have to be so complicated?????
Posted : 27/02/2015 6:38 pm
Try looking at the Bearbones website (it' a bikepacking website in case you're wondering). They feature the Cycle2charge dynamo at £48 ex postage. No idea if it's any good.
Posted : 27/02/2015 7:40 pm
Stigheed, the Cycle2Charge isn't a dynamo, it's a unit that allows the dynamo to charge phones, cameras, batteries, etc.
Posted : 27/02/2015 9:43 pm
Have you used it yet?
Posted : 27/02/2015 10:24 pm
I fitted a Shimano DH3D32 dynamo hub and B&M light to my Kona Min-ute, I went for the version without the reflector since it gives better visible distance my version also has the day light and the senso function which is all superfluous since its never turned off but rose bikes had a deal on.
http://www.rosebikes.co.uk/article/shimano-dh-3d32-disc-hub-dynamo/aid:670781
And
http://www.rosebikes.co.uk/article/b--m-lumotec-iq-cyo-t-senso-plus-60-lux/aid:457434
Id not intended to get a rear light but being so impressed with the front I'm going to get round to adding one soon, but this weekends project is replacing the crappy cable disc brakes with hydraulics.
Posted : 27/02/2015 10:28 pm
Shermer - As in the OP my light is a Busch & Müller iQ Luxos U.
I've just been out for a quick spin round the darker areas of Farnbrorough FC car park and the park next to it and it's very impressive indeed. If you're used to normal 200000000 lumen MTB lights your think it wasn't very bright, but that's not its purpose. The beam is like a dipped car headlight. By that I mean it covers about the same area and is nearly as bright! It's got various "shapes" to the beam so to speak but it's very even with no bright spots and a sharp cutoff at the edges. No light is wasted up in the air like on a round beam and I guess that means it's not dazzling anyone either. The high beam just makes it all a bit brighter.
Output in lumens? Not a clue. It's impossible to compare with my MTB lights but I wouldn't be surprised if it's the best part of 1000.
Not tested the USB port yet but I will do. 🙂
Posted : 27/02/2015 10:37 pm
Thanks for the write up! Really useful stuff! Any chance of some photos?
Posted : 27/02/2015 11:23 pm
Sooty I've got no chance of getting pics of the beam. You need to be moving to see it at its brightest. There's a link earlier in this thread to an American website, he's taken lots of beam shots. They're fairly accurate although I think they make it look a tad brighter than it actually is.
Posted : 28/02/2015 9:07 am
I understand you can mix and match hubs and lights, but is there a standard for the cables, plugs etc or are they all different?
Posted : 28/02/2015 12:49 pm
Some of the cables are coaxial others are plain copper wire and the son/Schmidt hubs use spade terminals and others use plastic push fit plugs that trap the wire against exposed contacts on the hub - like many bike products there is no [i]standard[/i] for the industry to follow
Posted : 28/02/2015 1:16 pm
Cables are easy. Most hubs come with a click together plastic plug that you pop bare wires into then plug onto the hub. It's an AC current so it doesn't matter which way round the wires go either.
Posted : 28/02/2015 1:37 pm
sounds not too much of a nightmare, thanks.
Posted : 28/02/2015 2:44 pm
It's not a nightmare to figure out or to cable up a system on a bike to a decent standard, but if you do decide to go down this route for lighting then i'd purchase a selection box of heat shrink tubing and a mini gas soldering iron with a heat gun attachment - plan where you need the heatshrink tubing before you attach any spade connectors or suchlike and work out suitable cable runs.
The heat shrink tubing will give you a bit extra protection as some of the wires can be a bit thin and may wear through if they rub on gear cables etc - take into account the full movement of the bars etc.
Once you use a dynamo for lighting you will never regret it - it's just so simple to jump on and ride without the faffing of [i]did i recharge the battery?[/i], i tend to leave my lights on all the time - total fit n' forget system and if i forget to charge my iPhone i can just plug it in for a boost.
Posted : 28/02/2015 2:53 pm
 rt60
Are there any decent non rack mounted rear lights for the Luxos?
Posted : 28/02/2015 2:58 pm
What's the exact model of Luxos light?, some taillights are not compatible - [url= http://www.peterwhitecycles.com/b&m-hl.asp ]see half way down this page for more info[/url]
Posted : 28/02/2015 3:05 pm
 rt60
Thanks for that,
I was looking at the iq2 Luxos U. It seems the secula will work with it.
Posted : 28/02/2015 3:17 pm
Just been out for a pootle and put my iPhone on charge to check it worked. 6.5 miles of riding, maybe 2-3 with the light on (daytime mode I assume being as its automatic) put 6% into my phone battery. Once you've been moving about 20 yards the LED on the bar switch goes red indicating USB power is available and you hear the "bong" noise from your phone indicating its charging. Works absolutely perfectly. Can't fault it.
All in all I'm very very happy with my choice. There's just longevity to test now...! It's all good quality kit so I see no reason it won't last well.
Rt60 yes, that's the light I've got. £84 from bike-discount.de.
Posted : 01/03/2015 3:05 pm
 rt60
Thanks PP, ordered from there.
It will give me some fettling to do until I can get back in the saddle.
Posted : 01/03/2015 4:46 pm
Why is the [url= http://www.rosebikes.co.uk/article/shimano-dh-3d32-disc-hub-dynamo/aid:670781 ]shimano hub[/url] linked to by Brother Will so cheap? Will it break?
Any recommendations for pre built dynamo 28" wheels? Preferably French/German retailers.
Posted : 02/03/2015 9:19 am
