Dynamo cable routin...
[Closed] Dynamo cable routing...
7 Users
Anyone any suggestions for routing dynamo wires on a suspension fork, that looks neater cable ties?
Posted : 03/08/2014 7:19 pm
I run mine up the right leg, over the fork crown to the other side, then tape it to the disc brake cable. It needs a fairly long wire, but looks a lot neater than having the wire flapping loose up to the handlebars.
Posted : 03/08/2014 7:35 pm
Thanks - how do you secure the cable to the fork leg?
Posted : 03/08/2014 8:00 pm
It's not ideal, but I just use white electrical tape (white fork lowers). I'd prefer a nicer look - on my touring bike I've got heat shrink tubing over the whole leg, but it's not really possible on chunky suspension forks.
Posted : 03/08/2014 8:08 pm
Recently worked on a fork that was specifically designed for dynamo wiring, it was tapped on the back to take a plastic channel for housing the wires. A bit of imagination could see something similar from a diy store being stuck on the back instead of screwed on.
Posted : 03/08/2014 8:13 pm
Use the DI2 wiring strips. There's loads of colours and it looks neat and tidy.
Posted : 03/08/2014 8:18 pm
Ha. I just had this same question and really tidied mine up, by running the cable down through the fork steerer using a bmx giro stem cap. Works a treat and the cable is out of the way.
I then use rubber o rings to secure the cable to the fork.
[url= http://www.chainreactioncycles.com/gusset-hole-in-the-head-star-nut-top-cap/rp-prod23953 ]Hollow stem cap star nut[/url]
Posted : 03/08/2014 8:26 pm
I was wondering about that, too - I'd worked out I could get a hollow SFN but didn't know about top caps.
Posted : 04/08/2014 1:05 pm
top caps
Like these?
[url= http://ep1.pinkbike.org/p4pb7405670/p4pb7405670.jp g" target="_blank">http://ep1.pinkbike.org/p4pb7405670/p4pb7405670.jp g"/> [/img][/url]
Posted : 04/08/2014 7:15 pm
Similar. The link in my post shows you the cap. On reflection I think that one looks neater as the hex bolt is inset rather than proud like the one I purchased.
Still, I think both provide a neater solution to routing the cable
Posted : 05/08/2014 7:19 am
Do you have any problems with the cable when the fork compresses? Any special measures needed to keep it off the tyre?
This is also my current arrangement, although I use a bIt of spiral cable wrap rather than tape for securing to the hose ( you can also just wrap the wire around the house if you have enough length). Self-adhesive hose guides would be a neat solution to fixing to the lower fork legs, but I just use cable ties.
Posted : 05/08/2014 8:26 am
I'd have thought as the cable is a thin piece of wire it shouldn't be too much of a problem?
I know the RS Turncoat had a specific warning about the wheel hitting the bottom of it, but it looks like it leaves a fairly big lump sticking out of the bottom of the steerer.
Posted : 05/08/2014 6:08 pm
I was more thinking of the loop of slack cable that'll form when the fork compresses, and the possibility of it snagging the tyre tread.
Posted : 06/08/2014 6:23 am
Liking the top cap idea.
Posted : 06/08/2014 6:32 am
