Dt Swiss movement i...
[Closed] Dt Swiss movement in rear wheel
4 Users
Had bearing replaced on one side on a 240 mtb hub about 2 months ago but there's sideways movement,could it be the axle and skewer worn? Wheel 2 years old and would 135 axle be the same as 142? Not sure if the difference is made up with the adaptors.
Posted : 21/03/2016 10:39 am
The axle's definitely the same so it won't be that. Play can be a lot of things, you need to get it in bits really. It's not very likely to be axle wear, more likely to be an issue with a bearing- either wear or fitment. TBH I'd suspect that new bearing first of all.
The 240 has a rep for being hard to work on but it's not really, it has one bearing which needs special tools to get at but the other 4 are all just like any other cartridge hub, so you can strip and rebuild it pretty easily. And the one hard-to-access bearing is very well protected so lasts for ages in normal use.
Posted : 21/03/2016 11:06 am
Depends, in my experience this is usually caused by people buying Non-DT bearings which aren't within tolerance and/or bashing them in wonky with a hammer & a socket set and flaring the hub shell.
There was also an American ebay seller offering 'DT compatible' axles a while back, these were a tiny bit too small and tended to also generate play as a result.
So long as you've used all DT parts and fitted them using the proper tools then you shouldn't have any play.
Can't really say any more without having a look at the hub, maybe talk it back to the shop or give TF tuned (the U.K. service center) a call.
Posted : 21/03/2016 11:12 am
TBH if you're going to fit things wrongly, you can do that with the proper tool just as easily as you can with a good alternative, ie correct sized sockets in this case. It's the operator that's the issue in both scenarios.
It's just an industry standard bearing so any known brand- FAG, INA, Koyo etc- from a reliable source should be absolutely fine. But cheapies will often cause problems. Hopefully the shop's used decent ones.
Posted : 21/03/2016 11:27 am
I would expect that the DS hub bearing is not fully seated. This is the trickier one to do right, and would give you a smidge of L/R play but look mainly ok. Does the freehub seem to sit slightly proud of the body?
Posted : 21/03/2016 12:07 pm
