Do I need fuse wire...
[Closed] Do I need fuse wire for Hope pin retention? (pic)
5 Users
Wire has snapped in several places, the pin just pushes in, but I see that CRC sell threaded pins for mono minis. I presume later models had a thread on the caliper for this and mine do not? so I must get some fuse wire tomorrow. Any other alternatives?
Posted : 09/04/2010 7:08 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=36812 ]hope clip[/url]
Posted : 09/04/2010 7:12 pm
how about seizing wire from a yacht chandlers.
something like this http://www.force4.co.uk/3144/Ormiston-Monel-Seizing-Wire.html
Posted : 09/04/2010 7:14 pm
Oh that makes sense stu. I guess you stick in the straight end and clip over the loop.
Posted : 09/04/2010 7:20 pm
That bikes filthy! Clean it!
Posted : 09/04/2010 7:22 pm
I have had a couple of sets of m4's and have at times run without them and never had a problem. Has anyone ever had one pull out or have I had a little bit of luck(mixed with a little bit of stupidity)?
Posted : 09/04/2010 7:23 pm
Spot on.
What a Wally trying to bend it straight to get it out.
There is always one muppett.
So the above photo one is not quite "clipped in"
Posted : 09/04/2010 7:24 pm
Yep.
the pin just needs turning 90 degrees so the clip will go all the way on.
Posted : 09/04/2010 7:28 pm
