Cutdown Army Gorete...
[Closed] Cutdown Army Goretex 'shorts' - finishing the cut ends?
4 Users
Hi All,
Due to several weeks of various hiccups, it took me til yesterday to finally get out in the wet and try my cut down army surplus shorts.
Overall impressions - excellent!
I wore my humvee lycra padded liners underneath and though it was only about 6C I didn't feel cold, surprising as I do feel the cold. Did run with my Buffalo on top though, and Gore windstopper gloves and took a while for the fingers to warm. This coldness was a bit of a shock!
My cut off shorts were cut off to the length of my Humvee 3/4's and added an inch, and my wife turned up the ends on the machine. I did think the cut ends seemed to flare out a little when on the bike, so was wondering about fastening them to reduce flap.
Has anyone done this?
Was thinking of either a simple draw cord through the turned ends, or possibly some velcro flap like on Humvees.
Thoughts?
....and discovered the delights of waterproof boots ( Spesh Deforsters ) as opposed to overshoes. No flappy bits and totally dry feet. Brill!
cheers
Q
Posted : 29/11/2009 11:47 am
draw cord thru the hem would be easy enough; depending on the wife's skills, she could easily open the seam up the leg a bit and run them in so they are narrower to the cuff..
Posted : 29/11/2009 11:57 am
langy: yes was thinking that. A draw cord is the simplest.
Hadn't thought of opening up the seam ( p'raps I ought to ask her advice - duh!) My wife's an excellent seamstress so it's no problem for her to do, but that would then need seam tape to re-proof the seam....but I suppose on the end it wouldn't matter....
Was just curious as to what others did.
Q
Posted : 29/11/2009 12:03 pm
i just left mine cut though angle so that are slighly short behind the knee..
might stitch a vee into the sides to make them a bit narrower
apart from that they work great
Posted : 29/11/2009 12:30 pm
Had mine sorted by a relative who knew what she was doing... Took a long vertical triangular cut on the outside of leg, removing about 1+1/2" at the bottom to nothing about a foot up, brought edges together to form a vertical hem inside the leg. Works a treat & you'd think they were bought that way.
Posted : 29/11/2009 12:46 pm
