Creaky post
[Closed] Creaky post
6 Users
Whats the consensus these days for greasing seatposts?  Mine's creaking like a bugger and I think it might be from over torquing but it needs it to stop it slipping. Sizing is definitely correct.  It's an aluminium (aren't all droppers?) post into a ti frame.  Grease?  Bitty anti-slip paste?
Cheers.
Posted : 24/09/2018 10:41 pm
I thought someone would be able to help with this one!
Posted : 25/09/2018 11:26 am
get it really clean, incl around the clamp and bolt, and then either grease, or if you have a slipping issue, then a bit of carbon paste to help with a lower torque.
The dropper one on my Anthem creaks after a few months and a clean of the collar and bolt sorts it, for another few months.. In my case grease works better than paste (alloy dropper, alloy frame)
Posted : 25/09/2018 11:39 am
I had this recently with an aluminium post (Thomson) in an aluminium frame. Started creaking with every pedal stroke. Really annoying.
Using a solvent degreaser (isopropyl), I cleaned the seatpost, removed disassembled and cleaned the clamp, and cleaned inside the frame tube <span style="font-size: 12.8px; line-height: 16.64px;">using a rag sprayed with degreaser and tied to a stick to get down the tube. Took my time and made sure everything was spotless.</span>
Then greased contact surfaces with light even film of copper grease, reassembled and torqued to the recommended NMs. I also made <span style="font-size: 12.8px; line-height: 16.64px;">sure I greased the threads of the clamp screw.</span>
Been silent the last few rides. Hope this helps
Posted : 25/09/2018 11:52 am
https://www.bikeradar.com/mtb/gear/article/angryasian-silence-those-persistent-mystery-creaks-44332/
Funnily enough in the article above the Cannondale Linseed oil trick worked on my Cannondale Rush swingarm.  I had the dreaded swingarm 'click'.
Posted : 25/09/2018 12:32 pm
Wipe clean and grease it. Also check saddle rails and clamp, and grease them too.
Posted : 25/09/2018 12:48 pm
Get it nice and clean and then apply some carbon paste
Posted : 25/09/2018 1:38 pm
