Creaking Pikes, wil...
[Closed] Creaking Pikes, will loctite help?
7 Users
Seems to be normal creaky crown steerer issue, they were second hand. Have read loctite 290 or a retaining compound can help.
Anyone used something like this successfully?
Posted : 05/05/2017 8:39 am
Hope this isn't a silly question but have you already greased your headset, axles and other potentially creaky parts?
I only ask as I thought I had the dreaded creaky CSU a while ago but it turned out to be something else running a bit dry.
Posted : 05/05/2017 8:48 am
Loctite 638 bearing retainer is what you want here, completely silenced mine
Posted : 05/05/2017 8:49 am
Are both top caps torqued to 28Nm? Mine seem to have a habit of unscrewing themselves. They creak when they come loose.
Posted : 05/05/2017 9:00 am
Make sure the air cap is nice and tight, apparently that's the cause of a lot of peoples creaks.
Edit: ^^ beat me by 19 seconds!
Posted : 05/05/2017 9:01 am
It's definitely the fork, had it off the bike and in the vice. Will nip the top caps up and see before trying the loctite, cheers.
Posted : 05/05/2017 10:52 am
28nm seems high torque.
Posted : 05/05/2017 10:53 am
where do you apply the loctite?
Posted : 05/05/2017 10:58 am
Yep, but it's what the manual says and it stops them creaking.
Posted : 05/05/2017 11:01 am
Big adjustable job then. Jim, if tightening the caps doesn't work I'll turn the bike over, clean and drip the loctite on bottom of crown steerer join. I guess you could try the top join aswell once the race is off.
Posted : 05/05/2017 11:24 am
It's not that tricky to achieve. Normal open ended spanner or socket will suffice.
Posted : 05/05/2017 12:24 pm
Bugger. Still creaking. Will try the loctite.
Posted : 05/05/2017 8:31 pm
Let us know how the loctite goes. Mine were making a horrible noise in Italy last year, more of a crack than a creak and no warranty option.
I looked at all options form a new CSU, to having it rebonded, neither being cheap. Luckily I managed to get a second hand CSU at a good price and no issues so far.
Posted : 06/05/2017 6:38 am
Tried 638 on the crown/steerer join with fork thoroughly clean, left for 24 hours. Didn't work 🙁
Have stripped all the front end cleaned and used grease on everything apart from bar/stem/steerer and it has mostly gone but still something there. Even tried swapping the carbon bars for aluminium just to see.
Posted : 17/05/2017 12:02 pm
