crank length --dark...
[Closed] crank length --darkside-- 177.5?
9 Users
anyone tall decided that this was worth doing? I definitely noticed the 5mm between 170 and 175. Is it a case of: 'if you are 6 foot 4 inches + then you probably should but it wouldn't make a huge difference to speed/fatigue if you didn't'. that's my answer to myself so far...
Posted : 24/02/2010 3:34 pm
If you use 180's on an MTB maybe.
Posted : 24/02/2010 3:38 pm
correct. Or you have to be someone powerful like Miguel Indurain or Tom Boonen (both ride 177.5) to get the most cadence and power (lovely french word souplesse(sp?)).
I ride 172.5 on the road - just to be a bit different again.
Posted : 24/02/2010 3:39 pm
If you noticed the 5mm (I didn't), Shirley you'll notice the 2.5mm?
Posted : 24/02/2010 3:40 pm
 Zone
yep.... do it! Just have to watch your ground clearance!
Posted : 24/02/2010 3:45 pm
Different to who? 172.5mm is 'standard' on the road, as 175 is on the MTB.
If you spin, I wouldn't bother, if you mash then go nuts!
Posted : 24/02/2010 4:07 pm
hmm interesting! i'm leaning toward a point of inertia, with your help!
Posted : 24/02/2010 9:59 pm
whats darkside???????????
Posted : 24/02/2010 10:02 pm
If you spin then 175 would be fine... If you grind top gear all the time then you need the extra leverage...and blow your knees appart 😉
Posted : 24/02/2010 10:03 pm
njee20 - different from the OP 😀
I've road raced for years. I know 170/172.5 are the popular cranks.
Posted : 24/02/2010 10:11 pm
I've had a 177.5 on my tt bike for a few years and found it to be ok. Just about to change to 172.5 to try reduce the hip niggle I've got.
Posted : 24/02/2010 10:29 pm
