Converting Hope Pro...
[Closed] Converting Hope Pro2 QR rear to 10mm QR (DT swiss / superstar stylee)
So - I want to stiffen up the rear end of my Orange 5 (insert joke here) and am just wondering which conversion kit I need for a Hope pro2 rear hub? I did the front QR to 9mm conversion on my hardtail and just needed to change the adaptors. Is it the same on the rear or do I have to swap out the axle like with those nasty maxle things?
Oh and are the Superstar 10mm QRs as reliable/good as DT swiss ones?
Posted : 27/05/2013 12:35 am
You need this
http://www.chainreactioncycles.com/Models.aspx?ModelID=18761
Bit cheaper here.
http://www.ukbikestore.co.uk/product/176/hub223/hope-pro-2-rear-10mm-thru-conversion-kit.html
I have both the DT and the superstar.
The DT and the SS are both good.I have a mint DT if you want one.
Addy in profile. ๐Ÿ˜‰
Posted : 27/05/2013 12:59 am
[url= http://www.wiggle.com.au/hope-pro-2-evo-mtb-rear-wheel-axle-conversion-kit/ ]This one on Wiggle?[/url]
So do you have to swap out the axles or is it just the end caps?
Edit - http://singletrackworld.com/forum/topic/pro2-rebuild - pretty much answers my question. Maybe should have done a search before asking ๐Ÿ™‚
Posted : 27/05/2013 1:20 am
That wiggle one is not correct, you need the kit with the axle like the CRC one linked a few posts up...
Posted : 27/05/2013 6:04 am
hugo.As your in oz it,s probably cheaper to buy a new one. ๐Ÿ˜‰
Posted : 27/05/2013 12:27 pm
