Compression adjust-...
[Closed] Compression adjust- a dummies guide
5 Users
 hora
Ok most of the forks I've owned didn't have compression (or I didn't own them long enough) 😆
Anyway- can someone explain the effects and more '+' wound on and more '-' in principle?
For instance if your fork tops out slightly - run slightly more rebound but what about the compression?
What if you are hitting alot of rocks/steep- you tend to run more compression (+) don't you?
Posted : 07/11/2011 3:52 pm
is it high or low speed compression?
Posted : 07/11/2011 3:56 pm
 hora
On one fork -its both. On another its just one setting (bottom of fork leg)- Mazz Z1's
Posted : 07/11/2011 3:57 pm
[url= http://locotuning.co.uk/compression-glossary.html ]Have a read of this [/url]
Posted : 07/11/2011 3:58 pm
Was gonna post an explanation but that explains it better than I can.
As a starting point. Wind off all the low speed. Everything else have in the middle. Then fiddle.
Posted : 07/11/2011 4:07 pm
Wind it all the way out, go ride, keep winding it in untill the fork feels 'stable'.
I always found it was a lot harsher than I first guessed.
The rebound has a similar effect, so the more compression you wind on, the more rebound you can add as it's using less travel for a given impact, so needs to rebound less, which makes it even more stable. In spain (big, long, fast, rocky decents) I fiddled with them until they felt right, but they also felt very harsh, untill we videod them and it showed they were doing a lot of work, I was just hitting things faster and they were absorbing a lot of impacts.
Posted : 07/11/2011 4:09 pm
Ohh and ignore the 'one click at a time'. On those Z1's its more like 'two or three turns at a time', one click at a time you'd still be fiddling at Christmas 2012!
Posted : 07/11/2011 4:14 pm
