Thought I saw an out front Wahoo/Exposure mount on a bike in a YouTube clip, but my Google Fu is weak and I'm struggling to find something specific. Wanting to put a Roam and a Race together.
Closest I can see is some sort of Wahoo/GoPro mount, and then a GoPro/Exposure mount, but that seems kind of clunky, and expensive.
What are any other folks using?
I've got one on my Canyon (because it's an integrated cockpit, it's naturally specific to Canyon...). It's actually Garmin but the mount is the same just rotated 90 degrees isn't it? As it happens, I got mine off Etsy because Canyon didn't have any in stock but there were various people on Etsy who could 3D print the mounts. Turned out both cheaper and better than the Canyon option (which doesn't have the Go-Pro protrusion which takes the light mount).
I've not seen one direct for Exposure, it needs the Go-Pro slot then a separate add-on for the light (which will vary depending on if you're using a cylindrical "pencil" light or one of the big ones with the triangular base mount).
Have a look for K-Edge, they do a whole range of mounts.
Love K-Edge mounts, but was hoping to avoid the cost of that and the Exposure adapter!
You just need to look on Amazon or AliExpress and places like that. You can pick up all sorts of adapters for peanuts but you'd definitely be paying a premium for K-Edge.
On Amazon, I've had a couple of Tusita mounts which have been fine.
BTW, Wahoo and Garmin mounts are not interchangeable as, I think, the tabs on Wahoo are thicker than Garmin's but loads of places sell the Wahoo "discs" (most mounts allow users to switch out the Garmin disc for a Wahoo disc).
Anything with a GoPro mount underneath will be much tidier than other mount options, assuming you light can be oriented appropriately.
See if there guys make anything: https://www.racewaredirect.co/
I just had browse thru some of the Raceware products and none of the ones I looked at seemed to have interchangeable discs so, for instance, you'd have to buy a new mount if you switched your Wahoo to a Garmin whereas with a lot of other mount manufacturers, you'd just spend ~£2 to buy a new disc.
(I'm interested in this as I have a Magene radar [cheapskate version of a Garmin Varia] which uses a Garmin-like mount but offset by 90°, so it's frustrating trying to find a suitable mount for my new bike as I need something which can re-orientate a Garmin mount)
I've used a GoPro-Exposure mount and it works well enough suspended under a computer mount (with a Maxx-D or an Equinox), though not exactly a cheap option.
https://singletrackworld.com/forum/bike-forum/garmin-and-light-mount-morsa-or-something-else/
I’ve got the Morsa with the exposure cleat on a go pro mount on the gravel bike. The road bike runs a cheap copy of a k edge again with go pro/cleat. I’d go for the k edge out of the two. It’s more solid and small bolts on the morsa aren’t great.
I bought an Exposure Go Pro thing that replaces the normal cleat but only realised after I fitted it it made the light a pain to remove so changed it back to the setup P20 has above (although I use a ESFLNT out front mount from AliExpress + a Rockbros split mount so I can run two lights side by side). It's not pretty :p
