Classic case of hea...
Classic case of headset standard confusion
The official spec for my new frame (2024 Orbea Laufey) are IS42/30 and IS52/40 according to the Orbea website.
My other frame (Revel Rascal) is IS42 IS52 and doesn't specify the second number for either top or bottom.
I had therefore bought this which is apparently 42/28.6 and has worked well so far.
https://ebay.us/m/K5Vwit
Color Black
Crown Race 40
Bearing Type Cartridge
Defined Color Black
S.H.I.S Upper IS42
S.H.I.S Lower IS52
S.H.I.S. Stem Clamp Diameter 28.6 Threadless
Lower Stack Height 1
Upper Stack Height 9
Can I buy the same headset for the Orbea and ignore the difference between 28.6 and 30 (I have no idea what it refers to, is it of any relevance?)
Thanks a lot!
Posted : 13/11/2025 7:12 am
The second number is the steerer diameter at that point. So bearing ID. 28.6 is 1 1/8.
Standard for a tapered steerer is 28.6 top, 40 bottom. (Actually 39.8 but usually referred to as 40)
I haven't seen 30 for the top before, hat's not even the annoying 1 1/4; standard. Because that would mean you'd have a different diameter stem as well? In suspect a 28.6 would be fine likely due to the conical compression washer.
Posted : 13/11/2025 7:22 am
@submarined That article you linked for me in my fork thread is very helpful
Posted by: submarined
Yup, will do, that's standard tapered steerer size. This might help understand(and the example given is the same as your dimensions)
Posted : 13/11/2025 10:27 am
Thank you but still totally confused. I appreciate that the top of the fork steerer tube is 28.6 BUT IS42/30 (as opposed to IS42/28.6) is a thing and on their blue paper I don't think Orbea have made a mistake. I'll try and put a IS42/28.6 and see what happens. l just thought I had finally understood headsets...
Posted : 15/11/2025 3:32 am
IS42/30 is a lower headset for a 1 1/8 straight steerer, the 30mm is where the steerer flares from 28.6mm where the crown race seats above the crown. It would come with a 30mm ID crown race rather than a 28.6mm ID compression ring.
Its not uncommon for manufacturers published specs to be wrong.
Posted : 15/11/2025 8:42 am
sillyoldman reacted
Posted by: bigyan
This. Some headset manufacturers quote it as "Lower IS42/30" and "Top IS42/28.6"
Posted : 15/11/2025 10:57 am
