Cheapest solution f...
[Closed] Cheapest solution from 9 speed Triple to Double?
7 Users
Setting up a second hand bike for an inexperienced rider. It came with XT 9 speed triple and 175 cranks. She needs a double and 170 cranks (165 if available). What is the simplest solution in terms of components that need to be bought/swapped? It's always more complicated than I imagine!
Thanks for any input,
Paul.
Posted : 23/04/2017 1:05 pm
any 9/10 sp double crank set should do it.
Posted : 23/04/2017 1:12 pm
Thanks. So the 9 speed chain will work ok and the front shifter?
Posted : 23/04/2017 1:28 pm
Chain will be OK. With the front shifter you'll have a spare 'click' and adjust the mech stop screws to limit the throw
Posted : 23/04/2017 2:33 pm
I'd be tempted to do away with front mech and go 1x 10
Posted : 23/04/2017 2:39 pm
This^ is what I did 🙂
Posted : 23/04/2017 3:07 pm
don't use the front shifter & mech beyond the lower two rings.
Posted : 23/04/2017 3:12 pm
Which would involve changing chainset, shifter, chain, cassette and rear mech. Hardly the simplest solution which is what the OP was asking for!
Posted : 23/04/2017 3:18 pm
Missed the staying 9speed !
Could do what I done bought a new bike and all my 11 speed stuff went on the other half's bike
Posted : 23/04/2017 3:48 pm
I'd be happy with a single ring set up but this is not ideal for the rider I'm setting it up for. If need be we will shell out for a new XT 10 speed double chainset and I've got a barely used 10 speed chain if the 9 speed one doesn't work for any reason.
I normally forget something important which involves spending more than planned and the budget is tight.
Thanks for the input.
Posted : 23/04/2017 7:08 pm
