I'm fairly convinced I could set up a test to show that Charlie could have been riding a fully road legal bike and not stopped in the space available.
A fully road-legal bike where the rider was riding with his hands on the tops.
A road bike with cowhorn bars, TT extensions or an MTB with bar ends - there are any number of hand positions where he wouldn't have been instantly on the brakes.
I knew a courier who rode a fixed gear with a "front brake" fitted which was utterly useless, he admitted it was only there so the bike was road legal. He never once used it.
Is there a pic from the other side? Would be interested to see what sort of gearing was being run.
Most of the other media images are a side on image and low resolution, but I doubt you could estimate the gearing given the potential variation in sprocket size.
My reading is that wilful neglect only applies if the injury occurs because of that wilful neglect.Correct. Without their being an injury I think the strongest charge that could be applied is dangerous cycling, with a £2500 fine. My reading of that charge is that there couldn't be an effective defense from someone riding a fixie without a front brake.
But what is the wilful neglect? If it's the lack of a front brake, then I would have thought that the same verdict would have to be given for both the manslaughter charge and the wanton and furious charge.
The 'effective defence' would be that the harm was not actually a direct result of the lack of a front brake.
[quote=crazy-legs ]A fully road-legal bike where the rider was riding with his hands on the tops.
You wouldn't even need to go to that extreme - I reckon steve's guests' Halfords specials would probably be sufficient.
There is an argument that if brakes are fitted but totally ineffective the bike is still illegal - though I note that in the case referenced earlier where that appeared to be the case the cyclist wasn't charged with manslaughter. I imagine it's a lot harder to prove. But we're not talking about totally ineffective - we're talking about brakes which meet whatever US legal code which specifies effectiveness of brakes (mentioned near the start of this thread), a bike just meeting that still wouldn't have stopped.
If it was useless then technically he'd be in breach of the same laws, especially if he knew it (and had commented on it publicly) and then was in an accident like this one.
The test I'd be interested to try is to check out the braking distance for a Boris bike and also for a cheapo bike shaped object.
Bit torn on this, on one hand I think if we want car drivers to face higher punishment for traffic crimes, so should this guy - I really think riding without brakes is a silly and reckless fad. But also think that he could have been on a standard road bike and the result would have been the same - result of the accident that is, not the court case.
They've gone home now so don't have access to try them now.
I might have a go with my TT bike later though. It has carbon wheels and pads (although pretty good brakes - Ultegra) and I'm interested in what effect those have. Braking seems pretty good but I haven't tried an emergency stop.
The causation issue isn't "could he have stopped" but "could he have reduced his speed enough to not cause death". That itself is dependent on the question "was shouting and hoping to avoid collision a reasonable approach or not". Only if it wasn't is the question of stoppability relevant.
In my experience, if you decide to avoid and not brake, the last thing you should do is shout. That will upset the pedestrian and make it more likely they will bolt in a random direction. As, tragically, appears to have been the case here.
well why didn't he fix the brake then - what a d1ck. There is no argueing against the fact that an effective front brake will stop you faster, and not having one pretty much means that you are not bothered about the risk to other people - hence a selfish ****.
Other things that you need to be road legal, like pedal reflectors, are much more dubious but don't really put other peoples lives at risk, only your own for the limited scope of their effectiveness.
Try it on that in the wet, Steve! My TT bike is pretty rubbish at stopping in the wet with a similar braking setup.
Though be careful about not going over the bars if you're doing it in the dry - if those brakes do work OK, then you're going to go over the bars a lot easier if you have a good TT position. Certainly the CofG on mine is a lot further forwards, and I'm sure I couldn't do a 0.5g stop on it.
I've got another wheelset with an alloy braking channel that I use in the wet and am planning to avoid using the Carbon wheels in anything other than the dry.
Unlike with the other bikes I don't think I'll got for a really quick stop on the first go, just in case. I'm going to try stopping from various speeds on the roadie with hydro's as well because that 3m from 15mph in the video sounds like bollocks to me. 3m from 15kmph maybe.
[quote=greyspoke ]The causation issue isn't "could he have stopped" but "could he have reduced his speed enough to not cause death". That itself is dependent on the question "was shouting and hoping to avoid collision a reasonable approach or not". Only if it wasn't is the question of stoppability relevant.
I don't believe shouting and hoping to avoid a collision is a reasonable approach, but given the apparent cause of death the question of how much he'd have had to reduce his speed is a tricky one - I think the prosecution had to prove that he'd have avoided the collision by braking (though that's not the only requirement) in order to make their case.
I tend to agree. From the POV of trying to avoid such collisions. I don't believe there is anything negligent about shouting though (when combined with other actions to avoid a collision).
with only one brake. the fixed wheel is a brake. don't perpetuate the tabloid myth.
Not necessarily - for manslaughter they'd just need to prove that the death related to the higher speed of impact (and sounds like they didn't manage that). The wanton and furious is slightly different - the wilful neglect only has to relate to the situation where there was an injury, as was the case here, although there is a "cause" element to that as well which is also open to interpetation.
I prefer the term "without effective brakes" myself.
I think this was the cornerstone of his defence. And probably were a judgement by the jury of his character came in, he tried to persuade them that he did everything reasonable to avoid the collision, but they didn't believe him. I don't think I do either,my feelings are that obviously he didn't intend to run her over, but a close pass whilst shouting abuse would be fine.
I'm kind of inclined that way myself. What he shouted (something like "get out of my effing way" twice) won't have helped either.
If that was the juries thinking then the verdict on the "wanton and furious" would still be ok (i.e. even if it didn't relate to him having effective brakes it'd still relate to wilful neglect).
[quote=franksinatra ]Just listened to the victims husband being interviewed on Radio 4. He is now campaigning for cyclists to fall under the same road laws as car drivers so, in this case, the charge would have been death by dangerous driving.
He was incredibly composed, measured and eloquent. He is a cyclist himself and is very pro cycling and the changes to law and awareness that he is now campaigning for seem perfectly sensible and justified.
http://www.bbc.co.uk/programmes/b091s82b#playt=02h10m02s
I've now listened to that - wow, he comes across really well in that, I'm not sure I would manage to be so composed and sensible in the circumstances. On the surface everything he says is totally sensible, and almost everything he suggests is a good idea - I'm hoping that awareness of this case alone might give a lot of those riding without brakes cause to reflect.
The only issue is the one I mentioned above - the subjective nature of the dangerous and careless driving offences is likely to result in cyclists being held to a much higher standards than drivers. I'm not sure that is sufficient for me to object to his suggested changes - the issue is more that drivers aren't held to a high enough standard. For both of the recent cases which appear to be being referenced http://www.bbc.co.uk/news/uk-england-hereford-worcester-33236920 and http://news.bbc.co.uk/1/hi/england/dorset/8197430.stm death by dangerous cycling wouldn't seem an inappropriate charge based on the strict legal criteria used for drivers. I'm still not quite sure why the rider in the first case (with no brakes in an area where cycling was banned) wasn't charged with manslaughter though! In reality of course such cases which might merit those charges are incredibly rare.
I suppose it's that I agree with Cycling UK, that any such changes should also include a shake up of the offences related to driving and the level of proof required for them: https://twitter.com/WeAreCyclingUK/status/900369914627796992
Yes, the police video looks pretty amateur, but I think there is a lot of pointless quibbling going on here- Especially with the stopping distance with brakes: I've just had a go with a disc draked hybrid & without actually measuring it, my own stopping distance looks pretty much like the one in the police video. In fact it was quite interesting to see how quickly you can stop, without locking or lifting a wheel. I've not ridden a fixie, but is anyone seriously arguing that a rear wheel retardation only bike can stop in the same distance as one with both brakes, let alone one using the fixie method. So the vid isn't 100% accurtae but it gives a realistic demonstration of the issue in my view.
[quote=epicsteve ]Not necessarily - for manslaughter they'd just need to prove that the death related to the higher speed of impact (and sounds like they didn't manage that).
I agree - but proving that would have been incredibly difficult if they'd tried. Apologies for not making that clearer.
aracer - I smell an appeal if that was what the jurors were shown and what the evidence was based on. It's so flawed as to be laughable.
That's not good grounds for an appeal, the defence should have seen that evidence ahead of the trial and therefore had the opportunity to cross examine on its utility and bring their own experts or trial evidence that contradicts it. Indeed whether the crown were planning to lead evidence like this or not, you wonder why the defence wouldn't perform trials with experienced fixie riders (or even the accused) to show what the stopping distance is relative to properly braked bikes if it was a major line of their defence.
[quote=imnotverygood ]Yes, the police video looks pretty amateur, but I think there is a lot of pointless quibbling going on here- Especially with the stopping distance with brakes: I've just had a go with a disc draked hybrid & without actually measuring it, my own stopping distance looks pretty much like the one in the police video. In fact it was quite interesting to see how quickly you can stop, without locking or lifting a wheel. I've not ridden a fixie, but is anyone seriously arguing that a rear wheel retardation only bike can stop in the same distance as one with both brakes, let alone one using the fixie method. So the vid isn't 100% accurtae but it gives a realistic demonstration of the issue in my view.
But the details are important "pretty much like" doesn't cut it - the science says that you can't stop in 3m from 15mph, hence the testing must be flawed. Nor is "realistic demonstration" sufficient. Because the issue isn't whether a fixie without a front brake can stop as fast - everybody agrees that it can't. The issue is whether he'd have been able to stop in the distance available with a front brake. The testing purportedly shows that he could have - I believe the testing is flawed and that there's still a reasonable doubt whether he'd have avoided the collision by braking with a front brake.
That isn't pointless quibbling - it's crucial to the case in a couple of respects. Firstly it validates his decision to swerve rather than brake as the actions of a reasonable and sensible cyclist. Most importantly though it removes the direct link between the illegal bike and the death, because there remains the possibility of the death occurring if he'd been riding a legal bike.
The defence would not have needed to get its own tests done. The first thing it should have done is identify a suitable expert who could review the police evidence. Based on the comments on this thread, it looks highly likely that such an expert would able to completely tear apart the police testing.
There would be no need for tests from the defence, if they could simply cross examine the police witness in court and completely destroy the credibility of the evidence they presented. For example, if the speed gun recorded the speed at a different point the barrister simply needs to ask the question "What was the speed immediately prior to braking?", which the police witness could not answer.
If that evidence had been discredited, then the prosecution case might even have collapsed there and then.
Ok - just did some more tests (I'm working from home co-ordinating the response to an ITT so am bored!):
The (very, very grippy) road outside my house is now bone dry. This time I paced out 6m and put a markers at the start and finish. I re-tried using both brakes on my disc braked roadie and was able to stop within the distance from 18mph fine - in fact I could do it modulating the brakes to avoid the back wheel lifting if I wanted.
I then tried from 18mph using the TT bike with carbon wheels and carbon specific pads (wheels and pads are both brand new and the pads are the ones that came with the wheels, tyres are part worn 23mm GP4000's). No chance I could stop in 6m - it was closer to 7m although that was consistent and didn't feel unsafe. Very strange smell from the pads after a few attempts though! Of all the bikes I have here I think that's probably the one with the longest braking distance however all my bikes have decent brakes and tyres on them so still don't know how it'd compare to cheapo bikes.
I also had a go back on the disc braked bike to see what speed I'd need to be doing to stop in 3m and that seems to be around 12-13mph or so. I then tried braking from the same speed with just the rear brake and, as expected, that took around 6m.
I'm surprised no one has discussed making jaywalking a crime in built up areas.
There have been a couple of mentions in the thread. Not on the basis that it should be done, but on the basis that if the family wanted to campaign for a change in the law then that might be the most effective one.
I mean, I hate to do this - but if you follow the "five whys" of this:
https://en.wikipedia.org/wiki/5_Whys
Collision between cyclist and pedestrian
Why? - The Pedestrian was unaware of cyclist approaching
Why? - The Pedestrian was not paying due care and attention
Why? - The pedestrian was on their phone and not following the highway code (which states pedestrians should use crossing when available)
Why? - (this particular portion of) The highway code is not law
Why? - The highway code contains advisory as well as mandatory guides.
Therefore, make the highway code, or the part referring to pedestrians using crossings, law.
I'd be interested in other peoples "five whys" on this. You see here I didn't include anything about the speed of the cyclist or the braking situation, because ultimately if the pedestrian was not in the road or was aware of the cyclist then this event may not of happened.
In my mind, the reason the deceased died is due to the brakes/speed/lack of evasion situation, but the brake isn't the cause of the accident.
[b]Please not, this is exploratory thinking, I'm not saying either party is/is not to blame. I'm thinking about problem solving at this stage[/b]
We don't ask those kind of questions because it is victim blaming. Unless they're on a bike, then it was totally their fault. 🙄
Why? - The highway code contains advisory as well as mandatory guides.Therefore, make the highway code, or the part referring to pedestrians using crossings, law.
Hah. Do you work in QA?
The crime/misdemeanour of Jaywalking was introduced in America as a "deliberate effort by promoters of automobiles, such as local auto clubs and dealers, to redefine streets as places where pedestrians do not belong."
What follows after jaywalking? Jaybiking?
lol, in a dev team who follow lean practices so used to adopting problem solving strategies for all sorts of bizarre tasks.
@plyphon changing the law so the pedestrian was committing an offence would not in any way affect the question of whether the cyclist was committing an offence. Possibly you are operating on a "single cause" assumption, but the law recognises there can be multiple causes of something: as long as something is a substantial cause of something else, then it is causative.
And I am struggling with your penultimate paragraph. The pedestrian died as a result of the collision (a very clear line of causation there). So the cause of the collision was the cause of death, surely?
Death of a pedestrianCollision between cyclist and pedestrian
Why? - Because she was hit by a bike
Why? - Because the oncoming cyclist decided to buzz her to teach her a lesson for not looking where she was going
Why? - Because he felt it might give her a fright and make her more careful next time
Why? - Because he cares much more about being right than doing the right thing
Why? - Because he's a twunt.
[quote=greyspoke ]@plyphon changing the law so the pedestrian was committing an offence would not in any way affect the question of whether the cyclist was committing an offence.
That's not really the point - he's looking at the best way to prevent such accidents (in the context that that's what the husband is calling for).
I tend to agree with some parts of the reasoning, but not others, and not the conclusion. Yes, the main cause of the collision/death was the pedestrian stepping into a road into the path of a vehicle on it and then relying on the cyclist avoiding the collision.
I imagine that if Charlie Alliston's lawyers wish to appeal the verdict on the grounds of the flaws in the police tests, then the burden of proof will now be on them to show that the test results were flawed, and also that correct testing would give results that would materially undermine the prosecution case.
In other words, now that the jury has seen and apparently accepted the police tests and given its verdict, it will no longer be sufficient for the defence simply to raise doubts about the tests. I suspect that for an appeal to be allowed/succeed, they would now need to undertake their own tests, and for those tests to give decisively different results compared with the police tests.
I presume that Charlie Alliston's defence was paid for by legal aid. I doubt that the legal aid pursekeepers will be willing to fund such testing now (after the trial) on a speculative basis, and I suspect that Charlie Alliston lacks the means to pay for it himself (and his unlikeability will not encourage anyone else to pay for it).
I'm not sure why we need yet another law. The current one, although old seems suitable and has resulted in a few convictions.
I can't help feeling if the cyclist hadn't been such a cock with his victim blaming attitude his future might be looking a little rosier than it appears at the moment.
She wasn't paying attention and he was riding like an idiot. A recipe for disaster.
Plyphon your third why was flawed - you appear to have been trying to make a connection to the HW code. Should just be a full stop after the phone. Then we need to ask why on the phone?
You might find she was arguing with someone on an Internet forum.
It really looks like the defence wanted to avoid any arguments about braking capability considering:
1) Their defence was that braking capability wasn't a factor in the incident
2) Even properly done tests would still show that a bike with just a rear brake would take twice as long to stop as one fitted with a front brake (and I think it's likely that with just a fixed wheel braking could be even longer).
The phone thing (which I'm not sure was proven anyway, as the defendant backed off from his comments later) isn't really the issue either. The pedestrian has a duty of care to themselves and others to make sure it's safe to do so before crossing the road, and that she didn't do. No need to speculate about the reasons etc.
Not taking that care was 100% a factor in her death. The subsequent activities of the cyclist and the lack of effective braking was a secondary factor, but still a factor.
It'll be interesting to see whether the judge comments on the pedestrian's actions during sentencing.
Just listened to the victims husband being interviewed on Radio 4. He is now campaigning for cyclists to fall under the same road laws as car drivers so, in this case, the charge would have been death by dangerous driving.He was incredibly composed, measured and eloquent. He is a cyclist himself and is very pro cycling and the changes to law and awareness that he is now campaigning for seem perfectly sensible and justified.
I listened to him too and thought He put the point forward well and in a balanced fashion.
It's about appropriate charges being available and by extension the appropriate sentencing guidelines applying to a guilty verdict...
I think there's two separate points here, you are of course right that the duty of care and responsibility owed to cyclists should equate to the responsibility and duty of care owed by cyclists towards others...
By extension the quality of evidence used to demonstrate the safety performance of a bicycle to a court should therefore be on par with the quality of evidence that would be used in a case involving a motor vehicle... The evidence for comparative stopping performance of bicycles used in this case appears to be rather inadequate, but it's fair to say 'better' evidence may well have not have favoured the defendant...
It's a fair point, but these things are currently 'conditional' ([url= http://www.cyclinguk.org/cyclists-library/regulations/lighting-regulations ]interesting reading[/url]), reflectors and lights are only needed for riding after dark a "Road legal" bike during daylight hours can become "illegal" at night... Many people (including myself) probably fall foul of the pedal reflector rule when commuting in the winter time in SPDs, but I've never seen any sort of enforcement applied...
Of course if you follow these arguments to their logical conclusions are you heading towards the DM readers favourite of applying "Bicycle MOTs"?... Discuss 😉
Beyond this case there are more things to consider...
greyspoke » @plyphon changing the law so the pedestrian was committing an offence would not in any way affect the question of whether the cyclist was committing an offence.
Indeed, I'm not challenging the court verdict or trying to challenge who was causing an offence at the time - i'm just trying to explore to the root cause of the incident so we can discover what needs to change to prevent this in the future.
So I made this connection because I seem to remember reading the defence stating there was a pedestrian crossing not far up the road but the deceased chose to cross before that crossing. The highway code suggests where possible, to always cross at a crossing. It was clearly possible in this instance (if the statement was correct and I am remembering it correctly) to use a crossing - hence the link!
This is what I'd like to explore more as root cause of the incident tbh. Had she been taking more care, well - you know. Brakes are great at avoiding collisions, but they can't stop an incident from unfolding in the first place.
I'm not excusing the cyclist for having an ill equipped bike, or his attitude. But you have to wonder.
As others have said, if the cyclist was less of an arrogant prick we might not even be talking about this case today.
Pedestrians are not traffic. They have been largely forced from their legal right to use the carriageway by the volume and speed of modern vehicles.
There is also the complication that there are still plenty of places without a pavement where pedestrians are forced to walk on the carriageway.
epicsteve - Member
suspect he would get plenty of support for that too from certain interests....not necessarily overtly at first.
Just got round to viewing one of the interviews with the husband of the lady that was killed. He does come over well and his points on the danger of no front brakes are well made, however he does seem to focus on that as the only reason she died, without any comment on the dangers of walking onto the road when it wasn't safe to do so. The BBC don't comment on it either and anyone seeing the interview or reading the BBC article would get the view that his wife wasn't at fault at all. Very, very poor journalism.
Hate the term jaywalking and making it a crime would be a terrible idea.
Surely, rather than tightening the rules, the ones we've got should be properly enforced?
FWIW, I agree.
And if she'd stepped right in front of a cyclist without there being any chance of avoiding a collision then the only story would be that. But the court accepted that in this case there was time for the cyclists to avoid a collision, if he had two working brakes and or used better judgment.
I'm not disputing that at all - just making the point that it wasn't the primary cause of her death.
ransos - Member
That almost sounds like the case against cyclists using roads. Replace 'pedestrians' with 'cyclists'.
Dont forget, there are 3 classes of road user with an inviolable right to use the road; pedestrians, equestrians and cyclists. The rest are licensed to do so.
[quote=epicsteve ]It'll be interesting to see whether the judge comments on the pedestrian's actions during sentencing.
Or that she wasn't wearing a helmet?
[quote=ransos ]Pedestrians are not traffic. They have been largely forced from their legal right to use the carriageway by the volume and speed of modern vehicles.
[quote=chakaping ]Hate the term jaywalking and making it a crime would be a terrible idea.
I agree with you both - the very use of the term jaywalking tends to make me disagree with it because of the historical context as mentioned above - it wasn't about pedestrian safety, it was about clearing the way for motor vehicles.
I'm not sure what (if any) the correct course of action here is - the HC already recommends using crossings, as mentioned during the trial.
[quote=epicsteve ]without any comment on the dangers of walking onto the road when it wasn't safe to do so. The BBC don't comment on it either and anyone seeing the interview or reading the BBC article would get the view that his wife wasn't at fault at all. Very, very poor journalism.
I suspect there's a laudable intention to avoid victim blaming. Not of course that it stops the media in other circumstances and we are getting a bit of the double standards that Martin Porter complains about - would the media be so silent about the errors of a cyclist who jumped off the pavement into the road and was mown down by a driver not paying attention?
It as a bit disappointing that he doesn't at least acknowledge that the primary cause of the incident was his wife walking into the road. Understandable maybe, but if he's busy promoting things for road safety reasons, then one way to avoid another family being put through the same ordeal is for pedestrians not to step into the road in front of bikes - I do wonder if she thought "it's only a bike, it will avoid me" when you wouldn't think that about a car.
[quote=boblo ]That almost sounds like the case against cyclists using roads. Replace 'pedestrians' with 'cyclists'.
I don't think that's the intent - I'm reading it that pedestrians have the right to be on the road, and that the current situation isn't a positive thing (and I agree, particularly given the context you mention).
BTW I thought I should mention that the discussion on this thread has been incredibly well measured. It's a subject which had all the ingredients to just blow up into stupid arguments, but even where we've disagreed with each other everybody has handled the discussion in a sensible way. Well done everybody!
Wonder if this [url= http://www.getreading.co.uk/news/reading-berkshire-news/cyclist-dies-after-crashing-pedestrian-12785475 ]cyclist and pedestrian incident[/url] will result in a prosecution?
If the cyclist wasnt a cyclist we wouldnt be talking about this story.
Its a non story made into one by cycling haters.
I know that the "wanton and furious" bit is being well discussed, but are we certain that that is what the guilty verdict entirely was?
The legislation is drafted as
35 Drivers of carriages injuring persons by furious driving.
Whosoever, having the charge of any carriage or vehicle, shall by wanton or furious driving or racing, [b]or other wilful misconduct, or by wilful neglect,[/b] do or cause to be done any bodily harm to any person whatsoever, shall be guilty of a misdemeanor, and being convicted thereof shall be liable, at the discretion of the court, to be imprisoned for any term not exceeding two years
So there doesn't need to be a finding of any wanton or furious driving or racing, there just needs to be "other wilful misconduct" or "wilful neglect", either of which could legitimately extend to deliberately riding a bike on the road which is non-compliant with the law - i.e. no second working brake.
Once its proven that he deliberately had no front brake (whether or not he knew that that was the law), and it is proven that actual bodily harm was done he's bang to rights surely?
I wonder if the "wanton and furious driving" phrase is just being lifted because it is good media?
If the cyclist wasnt a cyclist we wouldnt be talking about this story.Its a non story made into one by cycling haters.
I disagree - it's a legitimate prosecution made more interesting by the (thankfully) very rare circumstance of a cyclist killing a pedestrian along with the combination of a total arsehole of a defendant riding a bike not fit for the road.
We're all cyclists here and we've found the story interesting.
Only if it's proven that the harm occurred [u]because[/u] of the neglect.
Whosoever, having the charge of any carriage or vehicle, shall [b]by[/b] wanton or furious driving or racing, or other wilful misconduct, or [b]by[/b] wilful neglect, do or cause to be done any bodily harm to any person whatsoever, shall be guilty of a misdemeanor, and being convicted thereof shall be liable, at the discretion of the court, to be imprisoned for any term not exceeding two years
The harm must be caused [i]by[/i] the wanton or furious driving, wilful misconduct, or wilful neglect. If the accident and harm would have occurred even if a front brake was fitted, either because
a) it could not be said beyond a reasonable doubt that using a front brake would have prevented the collision and injury (hence the importance of the highly dodgy results of the police tests of stopping distances), or
b) a competent cyclist on a fully braked bike in the same situation would have done exactly what the defendant did, and swerved (rather than braked),
then the harm was not caused by wilful neglect. That leaves wanton and furious driving, and that does not seem to apply given the reported speeds etc., or wilful misconduct, which also does not seem to apply.
EDIT - I suppose it's possible that the jury deemed the behaviour of the defendant in the brief period between the pedestrian steeping into the road and the collision to be wanton and furious, inasmuch as he he shouted and swore at her to get out of the way. That shout could be interpreted as implying an attitude of cavalier arrogance, and suggesting that he was not going to make any concessions because he had right of way. However, that would be a huge assumption, and the words used could just as easily have been shouted in panic (and fear of a collision where he would probably have been more likely to come off worse than the pedestrian).
I'm not sure that's true, quite a lot of STW contributors are open that they rarely cycle.
That's not really relevant though other than as an actual cyclist the coverage given to this story increases the perception that people on bicycles pose a greater risk than is actually the case.
Subsequently it increases the likely hood I will be the victim of a malicious act by someone either a pedestrian or a motorist and then reduces the likelihood I will get any justice.
Both these points are real and significant problems made worse by this coverage whilst pedestrians being injured by people on bicycles just not an issue in comparison.
So yes lets have a discussion about road safety and once we've fixed the real problems we can move on onto the minor issues.
My reading of it is still that the jury thought, on the balance of evidence, that the lack of effective braking was a factor in the collision and contributed to the injuries the pedestrian suffered. I think that they also concluded that it was a forseable outcome of riding without effective brakes, but that the death of the pedestrian was a freak occurrence hence the not guilty on the manslaughter charge.
Either that or they just thought that manslaughter was a bit harsh, considering the pedestrians contribution, and went for the lower sentence. I reckon if it had been possible to charge him with causing death by dangerous they'd have downgraded that to a causing death by careless for the same reasons.
That was the expert evidence provided by the prosecution, so it's not very surprising...
Agreed, there is a burden of proof of causality - did the wilful neglect or misconduct (or wanton & furious driving) cause any bodily harm. But any bodily harm is a very small test to satisfy, so if (beyond reasonable doubt) having no front brake (wilful neglect or wilful misconduct) *any bodily harm* was caused, then the offence is committed.
I can see a common sense reasoning that if the force of impact would have been lessened, even by a small amount, then causality is proven in terms of causing any bodily harm. Common sense is allowed in the jury room, even if not guided by either the prosecution or the judge.
The prosecution had an opportunity to oppose that but weren't able to do so effectively - which might mean the CCTV evidence is a significant factor.
It's not like the jury didn't given the situation due attention either, given how long it took for them to give a verdict.
I don't see that any laws need changed. If anything, this case proves that the existing laws are sufficient protection. What we do need is better application of the driving laws (possibly by less sympathetic juries).
You can't appeal because the prosecution presented evidence that you didn't bother to debunk at the time. The opportunity was there and wasn't taken.
New evidence that couldn't reasonably been brought at the time of the original conviction would be needed if you want to challenge the testing.
You can't appeal because the prosecution presented evidence that you didn't bother to debunk at the time. The opportunity was there and wasn't taken.New evidence that couldn't reasonably been brought at the time of the original conviction would be needed if you want to challenge the testing.
I don't think that is correct. There have been cases where expert witness testimony was fatally flawed, but was given in court and the defence failed to spot and expose the erors in the expert witness testimony during the trial. When the errors were exposed after the trial and conviction, it resulted in appeals and the conviction being overturned.
The most famous one I can recall was [url= https://en.wikipedia.org/wiki/Sally_Clark ]Sally Clark[/url], where the expert witness stated that the probability of two child deaths in the same family as a result of Sudden Infant Death Syndrome was 1 in 73 million and so the deaths must have been murder, but it was later shown that that where there had been a Sudden Infant Death Syndrome child death, there was a much higher statistical probability of further such deaths in the family, and the figure of 1 in 73 million was completely wrong.
It's a matter of debate as to whether he could've avoided the victim by using a front brake, so IMO it was not unreasonable for him to swerve. If we accept that shouting and swerving is a reasonable course of action by a competent cyclist on a legal bike, then the argument about the fitment of a front brake is rendered irrelevant.
You mean the defence? It could be. Equally, it could be that the defence didn't do a very good job.
I'm not quite sure what to think about this - I agree and disagree - so I'll just leave it here for now:
http://www.bbc.co.uk/news/uk-41036581
May I suggest watching Channel 4 news from this evening.
The lady's husband, Mr Matt Biggs, is interviewed
One can only imagine what he has been through, including sitting in the Old Bailey for 10 days of which he talks about. Yet he doesn't allow himself to be pulled into the whole "them and us" rhetoric and raises some fine points with eloquence and dignity.
I hope he gets his wish.... That another family doesnt have go through what his has.
That was his defence and the jury didn't buy it. They've seen the CCTV footage which might prove that to be bollocks.
Sorry - meant the defence. Difficult to know whether the defence did a decent job or not, because it's entirely possible that CCTV makes the case difficult to defend.
****er who things his "skillz" put him above the laws of physics.
[quote=Ro5ey ]I hope he gets his wish.... That another family doesnt have go through what his has.
Which would still be most easily achieved by getting pedestrians not to walk into the road in front of bicycles.
There are very few circumstances where, to avoid an unexpected collision, you swerve but make no attempt to adjust your speed, or at the critical moment even having swerved you make no (or very limited) attempts to reduce speed further. I can accept that swerving and shouting might be good starting points, but even if it only becomes clear very shortly before impact that the shouting and swerving is having no effect, being able to apply the brakes you're legally required to have fitted will always make *some* (potentially small) difference.
That's a lot to fit within a very short space of time.
As an aside, a pedestrian stepped out in front of me yesterday. My instinctive reaction was to swerve round her. My bike has disc brakes and the road was dry.
i am not sure I agree on the word easily in that sentence, effectively perhaps?Which would still be most easily achieved by getting pedestrians not to walk into the road in front of bicycles.
I think though that either you or I will need to go and have a chat with him and explain he is fighting the wrong battle (after all the net effect of DBD cycling will be very similar to Injury by W&F), if drivers don't wake up expecting to kill people today, cyclists really won't.
He would be far better pushing for prosecution of all the cyclists who don't have front brakes (or reflectors, lights) or who jump lights / ride like idiots but who don't harm anyone - just as we have discussed before if you want to improve driving you don't focus on the cases where it goes catastrophically wrong you penalise the same behaviour the rest of the time.
Or perhaps he should be pushing for a law on bells, was in Scandinavia recently and I suspect the polite tinkle of a bell is more obvious, directional, less aggressive...
Which is much the same argument that self entitled car drivers use to justify banning bikes from the road (it's for our own safety, apparently).
Sod all use when someone decides to step out directly in front of you though. Unless someone designs one easily used whilst braking.
Not really.
There is a difference between someone doing something actively dangerous and someone going about their day to day business.
Whilst I am cycling along I would expect a car to pass me in a safe manner.
However if I decide to swerve into an outside lane without checking then whilst it would be nice if the driver managed to avoid me it still is my problem.
