Changing disk size?
[Closed] Changing disk size?
4 Users
Hi just a quick query
I am up grading my fork to a pair of 2016 revs from my old 2007 fox floats, I have a pair of m975 xtr brakes with 160 rotors but am not sure if they are post or IS mount. As I am up grading to qr15 I need new wheels as my old ones are shimano centre lock hubs I need a new disk, as I am buying hope hubs.......it has all got very complicated all of a sudden
Posted : 07/11/2015 9:46 am
Not sure what happend there basically I want to enlarge the rotor size but not sure what adaptor to buy? Any thought would be grand, cheers Chris
Posted : 07/11/2015 9:51 am
Posted : 07/11/2015 9:53 am
Hope Hubs, so you'll need a 6-bolt rotor.
Your 2016 Revs will be Post Mount.
Your M975 caliper will almost definitely be Post Mount (a photo would help)
This is IS mount
This is POST mount
So, if you want to keep 160mm, just buy any 160mm 6-bolt rotor.
If you want to go up a size, buy a 180mm rotor and a +20mm Post-to-Post adapter.
Posted : 07/11/2015 9:59 am
You want IS to Post Mount. Follow the link below and make the selection based on which disc size you want...
http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-is/rp-prod13743
Posted : 07/11/2015 10:00 am
You sure? All the pics on Google suggest it's IS.
Posted : 07/11/2015 10:06 am
[quote=teasel ]
Both variants were available. The IS mount was most commonly used on the rear. I have two bikes with 975s on. Each has a Post front, IS rear. However, I hoped that providing the images above would answer the question to the OPs satisfaction.
Posted : 07/11/2015 10:14 am
Ah, I see. In which case... as you were.
Edit : Heh. Scrolled down for a few more secs and what do I spot...?
Speed searching, eh.
Posted : 07/11/2015 10:17 am
Thank you all for the chuccle and very informative info! You guys are the best
Posted : 07/11/2015 10:27 am
