Change the travel i...
[Closed] Change the travel in RS Revelations
I only seem to have 90mm of travel on these forks.
LBS took out spacers (they were meant to take it down to 120) ... and yes, I have lost the spacers
I can buy a universal spacer kit ... but it doesn't apply to RC Rev solo air.
How do I know if I have solo or dual air (I accept that this is a very stupid question)
As there is a value for pressure on the top and bottom of the leg, can I assume it is dual air?
Ta!
Posted : 23/12/2016 3:19 pm
Does it have a air valve at the base of the air side leg?
Posted : 23/12/2016 3:31 pm
it does ...
Posted : 23/12/2016 3:36 pm
This is what you want:
http://www.tftuned.com/rockshox-all-travel-spacer-kit-all-2010-forks/p2092
Posted : 23/12/2016 5:43 pm
Doesn't taking out the spacers increase the travel?
Posted : 23/12/2016 6:24 pm
Maybe my fork is different, but to change the travel on a solo air revelation I had to get a different length air leg (I went from 130 to 150mm travel).
Posted : 23/12/2016 6:41 pm
To reduce travel on dual air revs you add spacers, so you haven't lost them they're just in the fork..
Sounds like a strip and service will get you back to 120mm to me.
Posted : 23/12/2016 8:11 pm
Arse - just ordered the spacers ...
Okay thanks for all the help .
I need to investigate further .... I had them reduced from 140mm and was handed back two spacers ...
Posted : 23/12/2016 10:18 pm
They'll have used a spacer travel kit and given you the extra spacers back...
Iirc you get 2x20mm and 4x10mm normally which wouldn't all be used.
Posted : 23/12/2016 11:19 pm
