Chainring bolts: Th...
[Closed] Chainring bolts: Threadlock? Grease? Anti-seize? or Dry??
[#2247366]
Just putting the rings on my new chainset and having a little 'moment'. Now, normally I use a threadlock on my chainring bolts but, having none left, I was thinking of using some grease, or some anti-seize copper grease compoundy-stuff. I won't be putting them in dry.
So, just thought I'd do a quick straw poll:
Grease?
Anti-seize?
Threadlock?
Ta
Posted : 02/12/2010 7:28 pm
grease gets my vote
Posted : 02/12/2010 7:32 pm
copaslip for me
Posted : 02/12/2010 7:37 pm
 dobo
dry!
Posted : 02/12/2010 7:39 pm
I'd go in dry or some locktite 😉
Posted : 02/12/2010 7:42 pm
Anything I may want to undo later gets greased whether or not the manufacturer approves.
Posted : 02/12/2010 7:43 pm
can i recommend not lock tighting them as i done it and i was a real pain in the a** trying to get them out the other day...
Posted : 02/12/2010 7:45 pm
 sv
Coppaslip/copper grease for mine too.
Posted : 02/12/2010 7:47 pm
Dry!
Posted : 02/12/2010 7:49 pm
hehehe, so coppaslip/copper grease, a bit of grease, one threadlock and a couple of dry.
Posted : 02/12/2010 8:01 pm
In order of preference,
Thread lock
Anti seize
Grease
Dry isn't even an option.
Posted : 02/12/2010 8:06 pm
Dry been ok here for steel ones. Any lube will be fine though.
Hang on I'll sound like more of an expert if I say:
"I use no other than Chris King modified NASA Space Shuttle grease-threadlock hybrid SAE40/50WD40GT85WTF111"
Posted : 02/12/2010 8:09 pm
Has that stuff got any copper in cynic-al?
Posted : 02/12/2010 8:15 pm
Copperslip for me.
Posted : 02/12/2010 8:46 pm
Slippery copper stuff it is. All done now, thanks for your imput chaps
Posted : 02/12/2010 8:51 pm
 dobo
why people put slippery copper stuff on something that you really dont want to unexpectantly undue on you is beyond me. i've never seized a bolt on a ring before..but then i ride my bike and replace rings every now and then 😉
Posted : 02/12/2010 8:56 pm
Folk need to believe they are using the ideal hi tech prduct.
Posted : 02/12/2010 9:06 pm
coppaslip is hardly hitech snake oil. Well proven in its correct use.
If you like to keep things for years and don't like drilling out seized bolts then don't do them up dry.
Dobo - coppaslip is not particularly slippy - its antiseize. I have never had a coppaslipped bolt undo of its own accord
Posted : 02/12/2010 9:10 pm
 pcb
+1 for coppaslip
 dobo
well you are a dinosaur TJ 😉
did you do a cheeky edit or am i really that drunk, anyway i have some shimano copperslip and use it but not there, i know what its like and was unly really trolling 😉 and found the op comment on slippry funny and worth a dig
Posted : 02/12/2010 9:12 pm
Why would you need antiseize on a stainless steel bolt, is it really going to corrode before the chain ring needs replacing anyway
Posted : 02/12/2010 9:39 pm
Cheeky edit dobo
Posted : 02/12/2010 9:41 pm
Never said "snake oil" TJ. Coppaslip is hi tech compared to grease and IMO/E unecessary on bikes.
Posted : 02/12/2010 10:06 pm
IMO/ E it is better at preventing parts seizing - but grease is almost as good an 6 million times better than dry
Its no hassle to buy a pot. I have a pot of ordinary grease, one of coppaslip and various grades of locktite. I just put the appropriate one on every thread. I think the coppaslip was about a fiver for half a kilo. I even stripped my new bike to apply it. I haven't had a bolt seize that has some on it.
Posted : 02/12/2010 10:14 pm
When I was cutting my teeth as an engineer I was told by an old boy in the work shop that if two metal surfaces meet and move, grease them, if they meet and don't move, use anti seize. Possibly over simplifying things but not a bad guide.
Pants! Did I just agree with TH? Sorry folks.
Posted : 02/12/2010 10:18 pm
How does that prove it's better than grease? The fact you stripped a bike to apply it tends to show you are keen to show it works and now have vested interest.
FWIW my time servicing commuter bikes showed me it's salt (including sweat on bikes used on turbos!) that seizes most components, although some seize just from water, like alu quill stems on old road bikes.
Posted : 02/12/2010 10:25 pm
Al - read what I wrote.
Its not proof. I didn't claimn it was.
You are right - its salt that accelerates corrosion that causes bolts to seize
I do it because my decades of experience tells me that if you don't put something on parts seize. Anti-seize lasts longer that grease in a thread. It does not wash out as quickly
In the past I have had bolts seize. Since using antiseize I haven't.
Posted : 02/12/2010 10:30 pm
TandemJeremy - Member
You are right
*retires after what feels like a lifetime's work*
EDIT 😀 x infinity
Posted : 02/12/2010 10:36 pm
Superglue all the way
Posted : 02/12/2010 11:41 pm
