Carbon bars
[Closed] Carbon bars
11 Users
 ady
Hi just got the new bikew and need to trim down the bars which are monkey light carbon.
Anyone know if its just a case of cutting them the same as alloy set.
Posted : 13/11/2009 3:28 pm
i used a sharp hacksaw and dont breath the dust in apart from that its same iirc
Posted : 13/11/2009 3:31 pm
Use a fine, hard and sharp blade, wear a dust mask.
IIRC the carbon shards/particles aren't so small to be dangerous unless you're doing really high speed machining, but I wouldn't take the risk.
Posted : 13/11/2009 3:37 pm
put tape round then 1st, stops them from splintering
Posted : 13/11/2009 3:41 pm
 ady
Thanks for inf0 😀 its off to the workshop hacksaw in hand then
Posted : 13/11/2009 3:50 pm
Have you actually ridden them yet? I find my Eastons to be fine width-wise.
Posted : 13/11/2009 4:22 pm
 fbk
What Mikey said - I was tempted to cut down the Monkeylites on my bike but I've actually got quite used to the width now. Don't even miss bar ends any more 😉
Posted : 13/11/2009 4:24 pm
I cut down you're old broken ones that I ponced off you with a junior hacksaw and a bit of lube 😉
Posted : 13/11/2009 4:30 pm
Measure twice, cut once (x2 in this case).
Posted : 13/11/2009 4:41 pm
+1 for try them first - you will get used to them. They are not that wide so you could be making an expensive mistake
Posted : 13/11/2009 4:44 pm
 br
Try them first, I'm upto 720mm now 😀
Just a bit marginal getting it through doors though...
Posted : 13/11/2009 7:30 pm
 nuke
Wonder if he cut them down? Pretty much every post after he posted "off to the workshop hacksaw in hand" was try them first.
Posted : 13/11/2009 7:34 pm
I was just thinking that 😀
Posted : 13/11/2009 8:40 pm
 ady
Hi have not cut them yet i have ridden the bike twice and am going to try them again tomorrow as agree with what people have said as do not want to cut them if i do not have to
Posted : 13/11/2009 9:08 pm
 ady
Done 3 hr ride this morning and the hacksaw will not be going near them as they seem fine.
Thanks for info all
Posted : 14/11/2009 2:56 pm
phew **wipes sweat from brow**
Posted : 14/11/2009 3:17 pm
BTW I only cut mine down as the end was broken in a crash 8)
Posted : 16/11/2009 9:34 am
