as per title really, about 2mm left to push on but it won't go. Driving me mad ...!
Take the remote off the bars and screw it onto the barb. DON'T press the lever while doing it or you will need to bleed it. ๐
He's right. Just screw it on.
Oh ok sram video says to wiggle it on...?
Depends on the model. Old ones push on (and in the guides you have to slice the hose to get it off). New ones are simply a screw thread barb and hose screws into it.
I followed the MBR video. Even with a stinking hangover it was very easy!
I hold it in a pair of pliers in one hand, and tap it home with a small hammer.
All done screwed it on after taking remote off. Brakes bled pads replaced reverb bled 16 tooth cog fitted, 50mm stem fitted , a successful days fettling.
