I'm trying to fit an XO1 BB30/PF30 crank into a 73mm PF30 BB. The SRAM instructions clearly state that a 73mm BB does not need spacers. When I tighten the crank onto the correct torque, there's still about 2-3 mm of movement. Strangely just the size of a spacer.
Any advice - is there an art to fettling the crank on further, should I just pop a spacer on...?
Posted : 02/11/2014 4:16 pm
Can you not take the play out with the adjustable collar on the crank?
Posted : 02/11/2014 4:18 pm
Wot he said (going by my S1400 crankset)
Posted : 02/11/2014 4:22 pm
Kudos and thanks to both of you. The instructions now make sense!
I have a feeling I'll be back later to ask about Hope Hubs ...
Posted : 02/11/2014 4:30 pm
