can you maxle a Rag...
[Closed] can you maxle a Ragely?
7 Users
i was wondering if anyone knew if you are able to fit a maxle axle in any of the Ragley frames?
was interested in one of the frames but am loathe to give up my dt wheels
any advice is appreciated
cheers
Posted : 23/12/2009 11:50 am
All Ragleys are 10mm standard rear axle. No plans to do a maxle rear at the moment, though I am doing one on a Nukeproof hardtail I'm working on for a 4x rider.
I thought DT axles were very swappable?
Posted : 23/12/2009 11:54 am
Thanks Brant
yeah the DT's are swappable but i do like the added security of the maxle.
the 4x Nukeproof sounds interesting, available to the public or just sponsored riders?
i like the look of the Blue pig but was hoping to be able to swap all my parts over to save hassle.
cheers again
Posted : 23/12/2009 11:57 am
The Nukeproof will be a production model - but it's very 4x - short seat tube, no front mech, etc. Nice though!
Maxle up front makes sense. Maxle in the rear for "normal" people is a bit overkill. Adding bolt on dropouts to allow it = extra cost, weight, etc...
I will have another look - I guess you could always drill it out!
Posted : 23/12/2009 12:06 pm
Enough meat on a Ti dropout I'd have thought?
Posted : 23/12/2009 12:08 pm
 ojom
Wouldn't see the need on a HT myself though. Although i do mince.
Posted : 23/12/2009 12:09 pm
Gotta love the mince.
Posted : 23/12/2009 12:14 pm
 ojom
ken, especially with tatties.
*remembers 2 packs of mince at home... dinner is dealt with!*
Posted : 23/12/2009 12:16 pm
10mm bolt through !
Posted : 23/12/2009 1:39 pm
i think i may be in luck! just checked the DT website and my rear maxle (it's a DT maxle) should actually be a 10mm
i'll double check when i get home but i coudl be in luck!
phew
oh i think the Ti version may be the weapon of choice 😉
Posted : 23/12/2009 1:55 pm
Slightly different question, but same area, if i can change my Hope Pro II rear hub to a bolt through can this be used on a normal frame with vertical dropouts?
Is the typical vertical dropouts 10mm or 12mm in most frames?
Posted : 23/12/2009 2:06 pm
normal dropouts are 10mm (9mm qr bolt)but it could be a tight fit, im going to have to do some more homework myself to ensure itll fit
Posted : 23/12/2009 2:12 pm
