Can you change the ...
[Closed] Can you change the range of travel on new U-turn revs?
 bol
I'd like to be able to change the travel on my revelations from 120-150 to 100-130. Is this doable? I know that I could probably just swap the forks, but knowing that I'm a bit of a tart at swapping frames at the moment, I'd like the option to swap them back again. Your knowledge, as ever, much appreciated.
Posted : 21/04/2010 8:22 pm
 bol
Bump for the daytimers...
Posted : 22/04/2010 7:03 am
No. Not really possible. If you really need that, your best bet is to sell them and get some older used ones....
Basically, you should have bought Rebas instead... ๐Ÿ˜•
Posted : 22/04/2010 8:29 am
 bol
Cheers Peter. Thought that might be the case. Yep, basically what I need is a set of each to allow for my general indecision about what bike I want.
Posted : 22/04/2010 4:26 pm
