can i run a 650b,29...
[Closed] can i run a 650b,29er crank on a 26er?
Hi thanks for reading this can I run a shimano m625 crank 38/24 10 speed on a 26er apparently they are for 750b,29er frames? Can anyone shed any light on this for me? Thank you
Posted : 16/04/2016 4:42 pm
so long as you get the correct type for your bottom bracket you can run whatever crank you want.
Posted : 16/04/2016 4:45 pm
 poah
no, won't fit lol
Posted : 16/04/2016 4:46 pm
What bb would I need?
Posted : 16/04/2016 4:48 pm
What frame is it?
Posted : 16/04/2016 5:22 pm
First I've heard of a wheel size specific crankset!!
Posted : 16/04/2016 5:26 pm
Any hollowtech, if its new it will come with one.
If not
https://www.merlincycles.com/shimano-bb52-deore-hollowtech2-bottom-bracket-51282.html
Posted : 16/04/2016 5:31 pm
Fizik did a wheel-size specific saddle, so stranger things have happened.
Posted : 16/04/2016 5:43 pm
It came off a 2015 Scott scale I want to put it on my evil sovereign
Posted : 16/04/2016 5:51 pm
Boost was partially introduced for 650plus wheels, so boost specific cranks with their adjusted chainline wouldnt be ideal on a 26/27.5 or 29 with 135mm rear end.
So there us some logic in the question.
Posted : 16/04/2016 5:56 pm
A fat bike crank won't fit
See above
Posted : 16/04/2016 7:11 pm
What 750b frame is it?
Some of them will be fine with that crank an on others it'll cause slow and torturess instant death.
Posted : 16/04/2016 7:16 pm
Not bothering sounds like too much hassle but thanks everyone
Posted : 16/04/2016 8:05 pm
