Can I bodge an I-Sp...
[Closed] Can I bodge an I-Spec A shifter to a B lever?
 PJay
[#10792990]
I've bought a pair of M780 XT shifters from the classified (both were correctly listed - SL-M780-B & SR-M780); however, being an I-Spec newbie I wasn't aware of versions A & B.
My M675 brake levers are I-Spec B.
The right hand shifter is I-Spec A (with a hook and nut) and nut &[url= https://www.bikeradar.com/features/shimano-i-spec-a-b-and-ii-mounts-explained/ ] it appears that I can't fit an I-Spec A shifter to a B lever[/url].
Is there an affordable bodge? SJS have a set of 2 covers that would convert both to B but at £22 plus postage it's a bit spendy. It looks like I could sort it out with just the silver I-spec mount for the right hand shifter but I can't find one.
Posted : 02/09/2019 1:40 pm
 PJay
Anyone? 😔
Posted : 03/09/2019 8:42 am
I looked into this when I bought new brakes for the hardtail without concentrating. All the options are more than you'd would to spend for a small piece of metal. I ended up nabbing the brakes off the singlespeed, and the SS got the new brakes that I couldn't fit shifters too.
Tried Problem Solvers and one-up?
Posted : 03/09/2019 9:03 am
 PJay
All I actually need is the bit below in I-Spec B flavour for a RH shifter (the image shows a type A mount and is located in Australia, so a non-starter) but they don't seem to be sold as spares (unless anyone knows differently). I might have to buy a set of M780 I-Spec B adapters for band-on shifters to get the piece or not use the shifters.
Posted : 03/09/2019 9:33 am
Can you not just dremel the hook off and widen the bolt hole?
This is a complete bodge but might work.
Or I have an Ispec-B 10speed XT shifter and an Ispec-B 2/3 speed SLX shifter kicking around.
Have you tried https://www.bikeparts.co.uk? When I knackered a Deore lever they appeared to sell practically every part.
Posted : 03/09/2019 10:59 am
I-spec A to I-spec B
Is this any good to you?
Posted : 03/09/2019 12:41 pm
 PJay
Thanks all!
Posted : 03/09/2019 1:51 pm
I've bodged it in the past with a small amount of fabrication/dremmeling and it's worked fine for years!
Posted : 03/09/2019 2:47 pm
The other option is Trickstuff in Germany - spendy but they make adapter for all, with a table so you can sort it out. I used them to fit Sram shifters to M785 shimano brakes. Great service, helpful and quick.
Posted : 03/09/2019 5:21 pm
You can bodge anything onto anything. If you own a dremel and a spoon drawer it shouldn't even be a question. I've got a 10 speed I-Spec B bar mounted to my hack bike with a bit of a 7 speed trigger shifter
Posted : 03/09/2019 5:24 pm
