broken chains and c...
[Closed] broken chains and chain tools
hi, chain broke again today, and after promising myself after the last time, i'm going to actually buy a damn chain tool for my bag!
Any suggestions on a good one? I've bought cheap before on tools, and regretted it, so i'm after a decent (but not ridiculously priced!) one for my bag.
Also - at what point would you recommend changing the cassette when i change my chain? I'm going to have to get a new chain, but my cassette is only new from september, so do i need a new one too?
Posted : 11/03/2012 9:08 pm
Have a look at this http://singletrackworld.com/forum/topic/which-chaintool
Posted : 11/03/2012 9:11 pm
thanks Nealy, ordered the superstar one, i am so not getting caught out and having to walk home again!
Any advice on the cassette from anyone?
Posted : 11/03/2012 9:28 pm
Teh only way is to try it - cahin only a bit worn you might get away with it - chain very worn - you won't
Posted : 11/03/2012 11:00 pm
thanks TJ, just had bike serviced and was advised chain was in good nick (apart from breaking...) so hopefully can sort without buying a new cassette.
Had thought of trying to repair with a powerlink thingy - but is this only for temp repairs to get you home, rather than a more permanent repair?
Posted : 11/03/2012 11:09 pm
powerlinks can be permanent - no trouble.
chains don't tend to just break - what are you doing with it?
Posted : 11/03/2012 11:21 pm
i know, trying to find what i'm doing wrong. I've not crossing over the gears, as i learned relatively early thats a good way to break a chain!
I broke it over at cannock, think i just tried to change both front and back mechs at once, and it got caught. Helpful passer by had a chain tool so removed a link and sorted it - but left it then and i'm thinking that would have weakened it? It went again today as i was going downhill, so not too much tension on chain, and no gear changing? Could it have been over tensioned as my rear sus moved?
Posted : 11/03/2012 11:25 pm
possibly a bent tooth on a chainring.
I'd always rejoin a chain with a powerlink, or a new pin with shimano. It's not worth the bother of it breaking again.
Posted : 12/03/2012 12:23 am
If it's for your bag, what you want is a Topeak Hexus- it's one of the best multitools out there and has a chain tool that's better than most expensive workshop tools.
Cassette- what you should do is replace the chain before it's too worn, that way the cassette is likely to take a new chain. But at this point, what you do is you fire on a new chain and hope it works, you'll soon know if it doesn't.
Posted : 12/03/2012 12:51 am
