Brake pad oddness, ...
[Closed] Brake pad oddness, what caused it?
7 Users
Same two pads
[url= https://i.ibb.co/W6R8mrM/IMG-20210323-194939794.jp g" target="_blank">https://i.ibb.co/W6R8mrM/IMG-20210323-194939794.jp g"/> [/img][/url]
[url= https://i.ibb.co/ckH2VyJ/IMG-20210323-194947842.jp g" target="_blank">https://i.ibb.co/ckH2VyJ/IMG-20210323-194947842.jp g"/> [/img][/url]
Posted : 23/03/2021 8:23 pm
Someone (some Animal 😁)putting the pads in back to front at some point ?
Posted : 23/03/2021 9:07 pm
That's my assumption
Posted : 23/03/2021 9:09 pm
May be incorrectly installed with pad material against pistons at first. Mistake was realised due the horrific noise!
Posted : 23/03/2021 9:11 pm
Just bought the bike ? Or was it you ?
Posted : 23/03/2021 9:33 pm
If you turn them round when they’re worn you get double the value?
Posted : 23/03/2021 10:01 pm
Looks like they've had it all, put in backwards, used on a too small rotor and used in a badly aligned caliper. Have the pistons survived the abuse unscathed.
Posted : 23/03/2021 10:27 pm
This is the start of tomorrow's job, customers pads
Posted : 24/03/2021 7:15 am
Pads installed from new, it's on a norco, Evans?
Posted : 24/03/2021 7:16 am
Will need new rotors!
Posted : 24/03/2021 7:17 am
Definitely this. Speaking as someone who has had a rotor shear, I can say this is a must.
Luckily I had done most of the stopping when the braking surface was cut in half....
Posted : 24/03/2021 7:45 am
